RF600 Gas Leaking From Carbs...HELP!!!! - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 7 (permalink) Old 12-23-2007, 09:01 PM Thread Starter
Newbie
Ok thought I would get the bike out one last time for a spin before winter really hits . It was almost 60 degrees yesterday and a great day to ride around the block a few times. Anyway put the battery back in the bike and tried to start it. Would not fire for anything. Finally after cranking and cranking it fired but only a couple of cylinders. Next thing I know there is gas pouring out of the overflow tube going to the carbs and looks like gas running out of the air box. As far as I could tell without taking off all the fairing and tank to be sure of where it is coming from. Does this sound like maybe a stuck float on one of the carbs? Anyone have any ideas I would appreciate it. Its a '94 Suzuki RF600. It has only sat for about a month since the last ride before it got too cold.
keller9431 is offline
post #2 of 7 (permalink) Old 12-23-2007, 11:04 PM
Stuck float or stuck needle jet.
Time to pull down the carbs for a rebuild / cleaning
Jeff
'73 H1 Triple is offline
post #3 of 7 (permalink) Old 12-23-2007, 11:06 PM Thread Starter
Newbie
The guy I bought the bike from said he had a shop rebuild the carbs last year. Should I rebuild or clean and if I just clean do I have to completely tear them down?
post #4 of 7 (permalink) Old 12-23-2007, 11:33 PM
I've never re-built carbs... or even seen them... save from pics... but he could have screwed something up putting back together...
post #5 of 7 (permalink) Old 12-24-2007, 12:21 AM
Does your RF use a fuel pump? Does the petcock have a Prime position? Does it have a fuel filter? If the RF uses Mikuni carbs, and the previous owner used a cheap rebuild kit, it could have brass float needles instead of viton tips. Most likely one or more float needle/seats are clogged or leaking.
post #6 of 7 (permalink) Old 12-24-2007, 09:06 AM Thread Starter
Newbie
The bike ran great this last summer. I put around 4000 miles on it just this summer with no problems. Yes the RF use a fuel pump, no prime position, and yes to the fuel filter. The bike does have Mikuni carbs. Sounds like I am going to have to tear them down and see. Why use viton tips instead of brass? Never heard of the viton tips.
post #7 of 7 (permalink) Old 12-24-2007, 09:13 AM
Lifetime Premium
vabarber2's Avatar
Brass tend to clog and are infereor.
vabarber2 is offline
