Galfer brake line question. - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 15 (permalink) Old 01-21-2008, 05:35 PM Thread Starter
Can anyone tell me if a set of Galfer brake lines for a 95-97 Kaw zx6r will fit my 98 zx9r? They are 28 1/2" overall length center to center and the ID of the end is 3/8.
Thanks
wingnut is offline
post #2 of 15 (permalink) Old 01-21-2008, 05:52 PM
measure yours and see if they match up.
dnyce is offline
post #3 of 15 (permalink) Old 01-21-2008, 06:00 PM Thread Starter
The length will work buy I'm not sure about the ID. I guess I can pull off a line and check.
wingnut is offline
post #4 of 15 (permalink) Old 01-21-2008, 06:03 PM
im 99% positive its the same size end
edit-you mean the inside diameter of the hose, or the fitting itself?
dnyce is offline
post #5 of 15 (permalink) Old 01-21-2008, 06:56 PM Thread Starter
The fitting. I took one off and it's 3/8 as well. Help me out here, sorry to sound like a noob but you get 2 lines with the Galfer kit, I have 3 one from the master to a splitter then 2 from the splitter to each caliper. On the Galfer setup do you just run both lines off the master to each caliper? do away with the splitter.
wingnut is offline
post #6 of 15 (permalink) Old 01-21-2008, 09:06 PM
I'd say they won't work then. If you only have two lines, one connects on both ends to the calipers. The other should be master cylinder to one caliper.
Got Gear?
post #7 of 15 (permalink) Old 01-21-2008, 10:17 PM
Run the two lines from the master with a two-hole banjo bolt. Then you won't need a splitter.
post #8 of 15 (permalink) Old 01-22-2008, 06:29 AM
I assumed one line was short
Got Gear?
post #9 of 15 (permalink) Old 01-22-2008, 12:52 PM
Nope, they should work, just check to see if they are long enough.
Most aftermarket SS line kits toss out the old stock setup of one line being split hear the horn and then running two lines from there. They will run two seperate lines from the master cylinder. The kit I bought but have not yet installed is that way.
They come with a banjo bolt for the MC that accepts two banjos on it.
post #10 of 15 (permalink) Old 01-22-2008, 07:46 PM Thread Starter
Cool ceo that is what I thought, Thanks for all your help.
wingnut is offline
post #11 of 15 (permalink) Old 01-23-2008, 04:10 PM
No problem man. I'm going to be doing mine once I'm finished building my workshop.
Another thing you might want to consider is 'speedbleeders' for your calipers. Since you are going to be putting in new banjo bolts anyways, you can find these bolts called speedbleeders that have a one-way valve built in that assists you in bleeding the brakes. They are also available in stainless (recommended). I'm probably going to get some of those.
Good luck
post #12 of 15 (permalink) Old 01-23-2008, 07:54 PM Thread Starter
WOW... Man last year I changed the fluid on the front and it took for ever to get them to bleed I started to freak it took so long. So where do I find Speed Bleeders sound like I could have used them then and now.
Great Info you DA MAN LOL.........
wingnut is offline
post #13 of 15 (permalink) Old 01-26-2008, 08:12 PM Thread Starter
Got the new lines, thay are going to work just fine. Take care guys.......
wingnut is offline
post #14 of 15 (permalink) Old 01-26-2008, 11:35 PM
Hey man, you're welcome. Sorry I didn't see this earlier, I haven't been on.
You can get speedbleeders from http://www.speedbleeder.com/
Like I said, I would spend the extra dough to get the stainless versions
post #15 of 15 (permalink) Old 01-28-2008, 05:17 PM Thread Starter
No problem ceo. I Googled them and found them. Saved as a favorite.
wingnut is offline
