ZX6R Engine mods - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 14 (permalink) Old 01-30-2008, 10:55 PM Thread Starter
ZX6R Engine mods
Is it worth it to go inside the motor? Big bore kits and cams? It will cost alot of mullah but I wonder if it is worth the money? So far I have a D&D pipe, jet kit, Timing advance kit, -1+2 520 conversion, ngk plugs, amsoil oil, and an ebc clutch kit.
BTW Its a 2000 zx6r with 14K miles.
jnn7404 is offline
post #2 of 14 (permalink) Old 01-30-2008, 11:10 PM
I'd try to find out if the ZX9r motor would fit and do a swap... probably cost the same if not less...
post #3 of 14 (permalink) Old 01-30-2008, 11:13 PM Thread Starter
I don't know how true this is but I heard you have to widen the frame for the zx9 motor.
jnn7404 is offline
post #4 of 14 (permalink) Old 01-30-2008, 11:31 PM
sell the 6 and buy a 9...
still probably cheaper than waste'n your time with the internals of the 6... maybe a ZX7r motor will fit.
the only way I'd mess with the internals of a 600 is if I were racing in a 600 class
post #5 of 14 (permalink) Old 01-30-2008, 11:32 PM
If you're that big of a power junkie just a liter class bike.
did I just say that
post #6 of 14 (permalink) Old 01-30-2008, 11:38 PM Thread Starter
Well I am wanting some more power but I don't really want or a need a liter bike. 14K miles on it already and I plan on logging in another 7K this year. It won't be long before a rebuild is necessary. I am just wondering what kind of power gain is to be expected and is it worth the $.
jnn7404 is offline
post #7 of 14 (permalink) Old 01-30-2008, 11:48 PM
your joking right? If you do regular maintenance, it may just out live you
post #8 of 14 (permalink) Old 01-30-2008, 11:57 PM Thread Starter
Well maintenance wise I stay on top of, but it's high reving gear dropping abuse that might or might not hold up. I am just getting a game plan up before it's time and too late. I am not going into a perfectly good bike. So if it takes a chit do I spend the extra money or go back stock?
jnn7404 is offline
post #9 of 14 (permalink) Old 01-31-2008, 12:34 PM
If it does crap out, then would be a good time to mod. Shouldn't cost too much to bore it over a little and port and polish the heads.....wait- can you do that on bikes? Are the cylinders plated or lined on yours?
Got Gear?
post #10 of 14 (permalink) Old 01-31-2008, 12:37 PM
Yes it can be done. May cost more depending tho. Its not as simple as rebuilding your ol 350 Small block.
post #11 of 14 (permalink) Old 01-31-2008, 03:37 PM
Yeah- I imagine replating costs a good bit. Too bad nobody makes a "ol small block" for bikes though. A good, simple engine in a bike that's not outdated would be fun.
And in no way should you bring harley into this. Their engines are more like the twit that puts a fat cam in his big block that he never plans to run anywhere.
Got Gear?
post #12 of 14 (permalink) Old 01-31-2008, 04:17 PM
you not see seen that vrod that runs the dragon have you??
think its a vrod anyhow. Def a Vtwin be it a S&S etc.
post #13 of 14 (permalink) Old 01-31-2008, 06:23 PM
I'm told that your bigger gains are seen when you do the proper head work with cams. I have never done that yet but I was turned away from doing a big bore kit to my bike unless I needed to have a bore job and recoating. I would say on a good running engine with no engine failures the best bang for the buck would be Ported heads and a nice set of cams with everything tuned in good!
If you have an internal engine failure then I would look for a Motor Swap either to a 9 or a new fuel injected 6. I'm sure a Ninja specific forum could be of better assistance to you.
Either way good luck and ride smart!
Joe4g63gsx is offline
post #14 of 14 (permalink) Old 02-02-2008, 06:20 AM
Lifetime Premium
vabarber2's Avatar
If you want the power then trade up! If you want a back up plan then bore that bich! If you want to hear of people who've done it check a ninja specific forum!
vabarber2 is offline
