86 ZL-600 ignition issue - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 2 (permalink) Old 03-20-2008, 03:04 PM Thread Starter
I bought an 86 ZL-600A Eliminator as a bit of a project bike. After cleaning up the carbs and a new battery I have a nice running bike...most of the time. What seems to be happening is that after running for a while, for some reason the bike seems to drop one of the coils off line intermittently. I think its usually the #1/#4 cylinders' coil because the tachometer will go to 0 while this is going on. The bike still runs, just no power for a bit until it comes back all of a sudden. Initially it seemed to only be this one coil but now on occasion the other one will drop off (Same symptoms but tach continues to operate). I have tried to search for broken wires by tugging and wiggling wires in the harness while running but to no avail. I also notice that the temp light flashes on and off intermittently but the engine doesnt seem excessively hot and the fan isn't usually on. I figured this was probably a separate issue. If you've had the patience to read this novel, any help would be appreciated. Thank you.
Kyates is offline
post #2 of 2 (permalink) Old 05-16-2008, 06:14 PM
yeah ive been having the same problem, except that it made me crash, my bike is also an '86 zl600a1. i believe that the coils my be bad, or the carbs are out of tune. im leaning more towards the coils. my bike is currently in the shop ill be finding out in a week what the problem is. if you want ill let you know what they find.
Blackfinger is offline
