battery problem - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 3 (permalink) Old 05-17-2008, 08:58 PM Thread Starter
battery problem
hi guys
i am having some issue with my 01 honda cbr600 f4i...i thought that my battery was dead when i wokeup a morning in tried to start it... so i bought a new battery, but after 2 weeks the battery died again...so i thought it was the regulator/rectifier...i bought a new one and replace it, chargup the battery but after a week died again...
what do you think is the problem coz i spent to much money on buying batteries?
thnx for the help
jda1313 is offline
post #2 of 3 (permalink) Old 05-21-2008, 08:14 AM
adjunct moderator
indianaroadracer's Avatar
The charging system needs checked before spending any more cash
Need to check resistance through the 3 stator legs versus each other and against ground. Also need to check AC output of the stator.
If that checks good then check the rectifier.
If both are good, then its typically a connection issue. However, a connection issue for the rectifier or stator usually creates heat and melts connectors and such so they are typically obvious.
All this can be done by buying an OEM service manual or by taking it to a MC mechanic.
indianaroadracer is offline
post #3 of 3 (permalink) Old 05-21-2008, 10:19 AM
MikeHump's Avatar
Or, if you happen to have a VAT-40 or know anyone with a VAT-40, you can test your stator, generator, starter, and battery within about 5 minutes or so.
MikeHump is offline
