Yes,also if the chain is too tight the bike will "pulse" because the sprocket, sprocket carrier and wheel are NOT perfect circles and the chain will have a tight spot guaranteed. I'm VERY picky about wheel alignment and bought a chain alignment tool and aftermarket chain adjusters. Hopefully you a strong friend,turn the wheel slowly until you find the tightest spot on the chain. loosen the axle and adjust the chain to spec- approx 1"+ about 1/4 to make up for the change when you tighten the axle. Get both sides the same,use a caliper,a metal ruler,a stick,count the threads on the adjuster,whatever you can do to get it as perfect as possible. Tighten the axle nut and recheck your play. If you adjusted it at the tightest point then the chain will be slightly tighter at that point than necessary but looser at the opposite side of the sprocket. If it's too tight at the tightest spot with the axle nut tight then loosen the axle nut and loosen each adj one wrench movement-you can only get so much of a turn with a wrench- be precise. Tighten the axle nut and you should be good to go. BTW if you have to loosen a chain always make sure the axle blocks are up against the adjusters,give the tire a kick,before you tighten it. If you take your time and get everything perfect now,all you'll have to do when you need to tighten the chain is keep track of the turns you put on each adj.
