&@#$*!!!! Need help diagnosing electrical problem - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 5 (permalink) Old 06-05-2008, 09:22 PM Thread Starter
I've been having a problem with my YZF750R that I can't seem to diagnose. I can ride for a little bit fine, but after about 10 min or so the bike starts sputtering, backfiring, etc. Gets worse and worse till bike shuts off. Once it cools off, I can start and ride a bit more, till heats up again. I replaced the coils (with used ones off a low mileage bike), and than it ran great for about 2 weeks then the same thing happens again. I ordered new caps, boots, coils, and replaced everything with new OEM parts but the problem is still there. Any help diagnosing the problem would be appreciated.
Thanks
-- Matt
bossmankx is offline
post #2 of 5 (permalink) Old 06-05-2008, 09:46 PM
adjunct moderator
indianaroadracer's Avatar
Did you happen to open your fuel tank to check the vented gas cap????
indianaroadracer is offline
post #3 of 5 (permalink) Old 06-06-2008, 02:18 PM
TIGGER's Avatar
+1 or the fuel filter? Try riding around with the gas cap open once and see if it does it again. Sputtering is almost always fuel delivery and not electrical. By moving the tank around to get to the plugs,you may be dislodging whatever is causing the problem. Once things settle back down,the problem resurfaces. You may even have some crap in the tank that is blocking the screen on the pump,if you have an in/on tank pump.
TIGGER is offline
post #4 of 5 (permalink) Old 06-06-2008, 11:40 PM Thread Starter
thanks guys. I checked the fuel system today. No blockage on the vent line or tube, riding with the gas cap open didnt help. Fuel filter OK, fuel pump pressure is good. I was and am still skeptical of a fuel issue, because the bike is backfiring erratically, not just sputtering like its starving for fuel.
post #5 of 5 (permalink) Old 06-07-2008, 03:17 PM
TIGGER's Avatar
Did you check the tip-over sensor? Neg batt terminal? Hmmm....
TIGGER is offline
