05 Gsxr 1000 Overheating?? - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 8 (permalink) Old 06-23-2008, 04:47 PM Thread Starter
I RECENTLY BOUGHT AN 05 GSXR 1000, AND ABSOLUTELY LOVE IT. ONE THING I DO NOTICE HOWEVER, IS IF IM SITTING AT A STOPLIGHT FOR MORE THAN ABOUT 30 SECONDS THE TEMPERATURE REACHES 210 PLUS!! ONCE I START TO MOVE THE TEMP GOES RIGHT BACK DOWN TO THE NORMAL OPERATING TEMP, (SEEMS TO BE AROUND 170-180 DEPENDING ON THE AMBIENT TEMPERATURE). IS THIS NORMAL OR WHAT?? THE LAST BIKE I HAD WAS AN INTERCEPTOR, AND IT RARELY REACHED OVER 200.
BSRJ IRONMAN is offline
post #2 of 8 (permalink) Old 06-24-2008, 10:08 AM
My Gixxer and the Busa would run about 3/4 on the temp gauge during times of heavy traffic. As long as the fan is kicking on and it stays out of the red, you're good. Also....I switched the coolant to Engine Ice and it seems to run cooler.
warputer is offline
post #3 of 8 (permalink) Old 06-24-2008, 06:04 PM
I don't think 210 is that bad. If the system is properly pressurized, you shouldn't boil over until you go over the 220-230 range. It also depends on the ambient temperature. If the condition you are describing is on a hot day, then it is completely normal. If it is reaching 210 on a cool day (<70F), then you may have an issue. Rule of thumb is, no boilover, no problem.
6doublefive321 is offline
post #4 of 8 (permalink) Old 06-25-2008, 11:29 AM Thread Starter
THE ONLY THING IM WORRIED ABOUT IS HOW FAST IT REACHES THAT TEMPERATURE. OH YEAH, AND THIS MORNING I WAS AT A STOPLIGHT, (AN OLD ONE WHERE THE WEIGHT OF MY BIKE WASNT TRIPPING THE TIMER), AND I BACKED UP SO I COULD TRY AND TRIP IT, AND I SAW A SMALL PUDDLE!!!!! I WAS SOOOO MAD. I JUST BOUGHT THIS BIKE AND I ALREADY FOUND TWO PROBLEMS! I THINK IT MIGHT BE THE RADIATOR CAP. I PULLED OFF THE RIGHT SIDE FAIRING AND THE LEAK LOOKS TO BE COMING OUT OF THE CAP. I THINK IM GOING TO HAVE IT CHECKED. THIS IS THE SECOND BIKE IVE HAD WITH PROBLEMS!!!
post #5 of 8 (permalink) Old 06-25-2008, 11:40 PM
Preliminary Diagnosis
Dude,
Whats the word on the street?
Hate to tell you this Im no expert but it sounds to me to be either one of two things that is either your Thermostat is not working proper or your fan is not working, and if I was a betting man I would say it was the latter. Reason being cause sitting still you heat up cause no air is passing thru the radiator to cool it down but when your rolling your good. Sounds like a fan issue to me.
Motorcycle Moto: If its too hot to wear it its too hot to ride!
Red Man is offline
post #6 of 8 (permalink) Old 06-26-2008, 01:58 PM Thread Starter
WELL ITS NOT THE CAP, I HAD IT TESTED, IT HOLDS PRESSURE FINE. THE FAN KICKS ON TOO SO I DONT KNOW. IM GOING TO RUN SOME TESTS AND TRY AND FIGURE OUT WHATS GOING ON. I LOOKED AT IT AGAIN, AND THE WATER LOOKS TO BE COMING OUT IF THE OVERFLOW TUBE. BUT THE RESERVOIR IS AT THE CORRECT LEVEL. IM GOING TO TAKE THE FAIRING OFF AND RUN IT AND WATCH IT AND SEE WHAT HAPPENS. I THINK THE MIXTURE OF COOLANT IS INCORRECT. I HAVE A BIGGER PROBLEM NOW. MY BATTERY KEEPS DYING AND IT LEAKED BATTERY ACID ALL OVER MY REAR SETS!!!!! IT DESTROYED THE ANODIZING ON THE LEFT ONE. MORE AND MORE I THINK THIS GUY SOLD ME A LEMON
HAS ANYONE ELSE HAD THIS PROBLEM, (WITH THE BATTERY)??
post #7 of 8 (permalink) Old 07-05-2008, 11:36 PM
Fujimoh's Avatar
Your battery sounds like it is being over charged and "boiling over"
My bike runs in the 170's out in clean air, but it will run 200+ in traffic and my fan kicks on about 224 or so
Fujimoh is offline
post #8 of 8 (permalink) Old 07-17-2008, 10:34 AM Thread Starter
Yeah, the battery that was in the bike was the worng battery. The previous owner grabbed a battery from napa or something before i bought it because the old battery was dead from sitting for a year. The battery was too small, so i bought a yuasa replacement battery and that part of it works great now. But the radiator has a leak near the cap, a crack to be precise. The previous owner really did not take care of this bike at all. while changing the oil and trying to fix the radiator, i found 2.....2!!!! MOTOR MOUNT BOLTS MISSING!!!! Wow. I had to special order these as they were really long (215mm) So those are in and the new radiator should be here today. After this is all done we'll see what else comes up
