2001 F4i not starting: Solutions? - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 3 (permalink) Old 07-11-2008, 09:23 PM Thread Starter
Hello,
After ending the riding season towards the end of last fall, my bike has been stored in my shed until now. When I attempted to start it, my bike was completely dead.
I attempted to hook it up to a quick-charge system. Ordinarily, after doing this for a few minutes, I would be able to start a bike up--even if it meant the charger had to stay on. But, even with the charger still hooked up, there's no dice.
I'm kind of broke at the moment, so can't afford to have it towed to the shop and such. I also don't want to experiment with buying parts. What could it be? Is it likely the battery, or would it be the regulator? Any other things to try before I purchase one of these?
Thanks!!
marcus314 is offline
post #2 of 3 (permalink) Old 07-12-2008, 06:48 PM
Originally Posted by marcus314 View Post
Hello,
Thanks!!
Most likely its the battery. Thats where I would start. You can take the battery out n take n have it tested to make sure its toast. MC batteries dont take well to long spells of non-use esp when its cold/freezing. After you have or know you have a good battery, your bike should start up or at least spin the starter. Once its started n warmed up you can check the voltage output with a multimeter, I think the most it should be putting out is like 14.8v. And the lowest shouldnt be below 12v. If either of those are off then its most likely the rectifier/regulator. If it doesnt have any output its prolly the stator shot.
post #3 of 3 (permalink) Old 07-13-2008, 01:33 PM
Back _Marker's Avatar
for some odd reason, once a battery fully drains (dead) it will never fully recover. methinks the cells short out. new batteries are not expensive. go replace it.
there's a method to test the charging system with a volt meter ( +1 or 2 volts when the engine is on , base voltage should be around 11.2-12 v).
