1999 Busa Shutting Down - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 2 (permalink) Old 08-03-2008, 06:34 AM Thread Starter
I was hoping someone would be able to provide some advice for my issue. At times when riding the highway, I go over a "large" bump and my Busa will shut off. It has happened now three times over about 12 trips and I can not find any pattern when it does happen. I usually travel at 65 mph and hit many bumps along the way. It does not happen on all bumps, or on the same bump.
Does anyone have some advice? Faulty Sensor? Something loose?
Natani is offline
post #2 of 2 (permalink) Old 08-06-2008, 11:17 AM
adjunct moderator
indianaroadracer's Avatar
I would check side stand switch and tip over sensor. I eliminated both on my bike. Stand switch just needs the two wires connected together and the tip over sensor has to be replaced by resisters at the same Ohm as the switch.
indianaroadracer is offline
