Bike jumps forward a little when put in first. - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 3 (permalink) Old 09-29-2008, 10:50 AM Thread Starter
Newbie
DavyJon3s's Avatar
Bike jumps forward a little when put in first gear. I will be at a stop light and i go to bump it into first and it will role forward 6 inches even with the clutch fully pulled to the handle bar.
Also on occasion i cant get it to come out of neutral. and i need to wiggle the bike or role it back or forward a little to get it to engage.
Are these normality's or do i need it looked at?
Bike in Reference: 84 Honda V65 Sabre (50,000 km)
Cheers,
Dave
Remember folks, street lights timed for 35 mph are also timed for 70 mph.
DavyJon3s is offline
post #2 of 3 (permalink) Old 09-29-2008, 05:31 PM
Clutch cable needs to be adjusted first. There should be only a slight bit of play in leaver when adjusted properly. If cable runs out of adjustment, you may need to replace the cable or the clutch. As for getting it into neutral. Most bikes need a lil effort to change gears while not in motion.
post #3 of 3 (permalink) Old 10-29-2008, 09:10 PM
yup its that clutch cable and he is definitely right about finding neutral. safe riding
jamesgsxrc is offline
