Battery for Suzuki SV - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 14 (permalink) Old 01-16-2005, 10:55 AM Thread Starter
Looks like the battery in my '99 SVS needs a new one. After spending most of its life in the Arizona heat, I'm surprised I'm only on #2.
But, I tried to start it this morning (35 degrees) and if my bike hadn't turned over when it did it would be sitting on a charger right now.
So, where is the best place to get a battery? Mail-order doesn't seem like deal considering the weight. Unless you buy the electrolyte locally, but if I'm going to do that I might as well just buy the whole thing locally. I only shy away from that because of the cost, but for an item like this is might actually me cheaper?
What are your recommendations for a new battery? OEM? Sealed after-market?
post #2 of 14 (permalink) Old 01-16-2005, 12:18 PM
I have heard really good things about the Wesco (sp?) sealed batts...big amoung the BMW crowd...
desmo900rider is offline
post #3 of 14 (permalink) Old 01-16-2005, 02:26 PM
I hate most of the batteries out there for bikes!! They just suck!!
I've bought many different brands and the same result.... they suck!!!
Some type of sealed would most likely be best....good luck and post up what you find. I'm always looking for a good battery for my bike, because the rest of them....well you know....SUCK!!
post #4 of 14 (permalink) Old 01-16-2005, 09:06 PM
Most places should ship a sealed battery. The battery comes packaged with its own acid pack and you put the acid in yourself and then charge it before you use it. I don't necessarily agree with Gas Man on this one, I have had good luck with Yuasa and Interstate (made by Yuasa, IIRC) batteries but they are not cheap. If you want cheap, we have a chain of stores up here called Batteries Plus that I have heard good things about. You may want to see if they are in your area as well.
post #5 of 14 (permalink) Old 01-16-2005, 10:08 PM
I have purchsed actual Yuasa and have a Interstate (which yes is a Yuasa) in the 9R now. But they both suck and both come as Larry says!!
They (batt manufactures) should offer better batteries as they do for cars!!! I wish they made a optimuim brand battery for bikes but they don't!!!
post #6 of 14 (permalink) Old 01-17-2005, 07:13 AM Thread Starter
I went with OEM last time around, not sure what brand that is. But, bike batteries sure don't last as long as car batteries.
I'll get some prices on a Yuasa.
post #7 of 14 (permalink) Old 01-17-2005, 09:37 PM
Almost all standard MC batts are Yuasa!
post #8 of 14 (permalink) Old 01-17-2005, 09:59 PM
OEM usually is Yuasa. The big problem with bike batteries is not the battery but the environment. The battery makers have to deal with size limitations, heat, vibration, and often times less than stellar starting and charging systems. When I sold my 93 ZR1100 in 03 it still had the original battery and fired every time even if it sat for months...sometimes it is just luck of the draw (no pun intended).
post #9 of 14 (permalink) Old 02-14-2005, 09:40 PM
I had my Suzuki battery (Diehard) and my Honda battery (Yuasa) out for charging. They look exactly the same. I think Yuasa does make all of the motorcycle batteries.
post #10 of 14 (permalink) Old 02-14-2005, 09:51 PM
i think the older batteries of the 80's and early 90's lasted longer than the newer ones...use to get 3-5 years easy out of them, now your lucky to get 2 full seasons...just my thoughts on batteries for the last 30 years of bike riding...
GsxrJack is offline
post #11 of 14 (permalink) Old 02-14-2005, 10:41 PM
you have the 650 or the 1000???
bulldog is offline
post #12 of 14 (permalink) Old 02-15-2005, 08:36 PM
here you go!! all glass mat batteries. Vibration and heat resistant. you can mount in any position also
http://www.motorcyclebatteriesusa.co...sp?battery=239
valpoboyzkenny is offline
post #13 of 14 (permalink) Old 02-15-2005, 09:54 PM
Shan, buy that and tell us how it does... NOW! how bout...NOW!
post #14 of 14 (permalink) Old 02-16-2005, 07:55 AM Thread Starter
650...
