'86 GSXR 750h firing on 2 cyliders, please help?? - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 3 (permalink) Old 05-08-2009, 01:48 PM Thread Starter
Thanks to anyone who takes the time to look through this.
I have an old 86 slabbie which I have run and maintained for donkeys years, its been sat a few months over the winter without running. Went to blow off the dust the other night but when I fired her up she only ran on cylinders 2 & 4???? I have put clean fresh fuel in her, replaced the spark plugs, done a fuel float and compression test, strip down and cleaned the carbs (pilot & main jet, float chambers etc) put her all back together and still only firing on 2 cylinders?? Any advice??
Thanks in advance,
Lee.
gixernitro is offline
post #2 of 3 (permalink) Old 05-08-2009, 09:42 PM
Newbie
Thanks in advance,
Lee.
Coil going bad? On those old Gix's, doesn't 1 coil fire 1 and 3 and the other 2 and 4?
JohnC is offline
post #3 of 3 (permalink) Old 05-09-2009, 04:33 AM Thread Starter
Yeah I had thought about that but when removing the plugs from 1 and 3 I have good deep blue spark so that kinda takes me away from thinking its the coil. Will try swapping them round and see if it fires on 1 and 3 and misses 2 and 4. Might be ok when out, but sparks blowing out under compression if coil cant sustain it.
Cheers.
