All power gone randomely - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 6 (permalink) Old 06-27-2009, 03:02 PM Thread Starter
I have an '02 gsxr 600. I was pulling it out of a parking spot and when i went to hit the starter all power to the bike shut off. No lights, no noise from the fuel pump....nothing. Nothing happens when i turn the key to on. I checked the ignition fuse but that seems to be fine.
any ideas?
thanks for the help!
dre968 is offline
post #2 of 6 (permalink) Old 06-28-2009, 06:58 AM
Ignition switch or right hand control switch is being faulty.
post #3 of 6 (permalink) Old 06-29-2009, 04:20 PM
Maybe your battery went bad
TXEMT is offline
post #4 of 6 (permalink) Old 07-04-2009, 12:39 PM Thread Starter
sorry for my ignorance i'm new to bikes. Is the right hand control switch the same as the engine cut off switch? I dont think it could be that since nothing goes on, not even my lights or anything. It seems that even if that switch is in the off position i should still be able to get lights and gauges. Also I really doubt its the battery since it was so sudden, if it were the battery i would expect a gradual issue with starting and lights and so forth. Not an immediate problem with everything dieing at once.
i guess i'll pull the ignition switch and see what happens.
dre968 is offline
post #5 of 6 (permalink) Old 07-05-2009, 06:28 PM
Battery voltage? Needs to be 12.8V
post #6 of 6 (permalink) Old 07-07-2009, 02:11 PM
Newbie
Sometimes batteries are like lightbulbs, you flip the switch and their blown. Its not always a gradual decrease in power.
I would clean the battery connections, and make sure they are good and tight as well.
Follow me on Twitter, http://twitter.com/BohannonBattery
Jbo24 is offline
