Bike Won't Stay on. - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 3 (permalink) Old 09-25-2009, 01:01 AM Thread Starter
griffter911's Avatar
Bike Won't Stay on.
Ok so my bike just had a dead battery. I charged the battery, but now when I try to start the bike, I have to pull the choke all the way out, and it starts at VERY low rpms and only stays on for a few seconds.
Any ideas what is going on?
"NON SIBI SED PATRIAE"
griffter911 is offline
post #2 of 3 (permalink) Old 03-22-2010, 05:44 PM
low rpms?
there could be a few reasons the bike is having trouble running, how long did the bike sit without starting? A simple thing to do would be to adjust the idle slightly, but that may only mask the real problem.
You may want to simply drain the sediment wells on your carburetor, and see how much sediment there is in the gas that comes out, this might solve the problem right there. I had a similar problem a few weeks ago, and this cleared it up, temporarily, if there is much sediment, it's probably rust, and likely from the gas tank, so take a look inside the tank to see.
What fixed the bike for me was a combo of cleaning the entire sediment wells and retuning the carburetor.
hope this helps
Alex
Also, simple stuff, make sure the gas switch is in the on position. and when you clean the sediment well, put the bike on the center stand, as this will completely drain the well. And, when your done with the sediment wells, make sure to prime your bike, so there is gas in the carb again. finally, MAKE SURE YOUR GAS VALVE IS OFF OR THAT GAS WILL NOT COME OUT OF THE WELL WHILE YOU ARE SERVICING THE BIKE! this could be a mess and a huge fire hazard
alexmblood is offline
post #3 of 3 (permalink) Old 04-01-2010, 09:13 AM
Newbie
Hey
Take A volt meter and put it on the battery. Then start the bike. The voltage should read somewhere between 13 to 14.5 volts. If not then you stator is bad and needs to be replaced.
Josh
Http://www.BohannonBattery.com
"For All Your Needs"
Jbo24 is offline
