Engine wont rev - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 3 (permalink) Old 09-30-2009, 12:41 AM Thread Starter
Engine wont rev
I just picked up a 1987 Honda XL250R dualsport. The bike sat untouched for two years. The problem is the engine won't rev up and won't go past 30 MPH. The engine is a single cylinder with a dual carb set up. First thing I did was took out the jets, cleaned them very good with carb cleaner, and blew some air through to make sure they were cleaned out. Didn't work. I then took off the exhaust to make sure the wasn't a nest from any critters. It was clean. If you could help it would be appreciated.
chicagojoe is offline
post #2 of 3 (permalink) Old 10-25-2009, 09:11 PM
Carbs
When you pulled the jets did you clean the rest of the carbs? There could be a secondary jet or port plugged or even the needle valve could be gummed up.
jhand2 is offline
post #3 of 3 (permalink) Old 11-04-2009, 10:19 PM
did you clean out the carb not just the jets but the whole carb some times the passages get cloged as well
infamousgsxr750 is offline
