Amsoil Synthetic SAE 60 Cycle and 20w-50 MotorCycle Oils - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 1 (permalink) Old 10-29-2010, 09:17 PM Thread Starter
Synthetic SAE 60 Motorcycle Oil (Part # MCS)
API SG, SL/CF JASO MA/MA2 ISO-L-EMA2 API GL-1
High-Performance Lubricant for Motorcycle Engines and Transmissions
AMSOIL SAE 60 Motorcycle Oil features superior heat resistance and wear protection. It is shear-stable and helps maintain proper oil pressure in elevated temperatures. AMSOIL Synthetic SAE 60 Motorcycle Oil stops viscosity breakdown (loss), protects gears and chains, and meets SAE 140, API GL-1 gear oil requirements. It is multi-functional and fulfills the requirements of both domestic and foreign motorcycles. AMSOIL SAE 60 Motorcycle Oil outperforms other conventional and synthetic motorcycle oils.
SAE 20W-50 Synthetic Motorcycle Oil (Part # MCV)
High Performance Lubricant for Engines, Transmissions and Primary Chaincases
API SG, SL/CF, CG-4; JASO MA/MA2; ISO-L-EMA2; API GL-1
AMSOIL MCV is multi-functional and fulfills the requirements of both domestic and foreign motorcycles. It outperforms other conventional and synthetic motorcycle oil.
You can look-up or order on my Dealer Website link:
http://www.lubedealer.com/MotorSportOil/
or emial
[email protected]
jeffh27 is offline
