Battery charging question - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 4 (permalink) Old 01-02-2011, 06:10 PM Thread Starter
I have a CB12A-A motorcycle battery I just bought, and in the dura-last manual said it should take 12 hours on a 500m Amp charger to charge the battery, but all i have is a 2 amp charger. Does that mean it would take just three hours to charge, or will I damage the battery?
schlamphure is offline
post #2 of 4 (permalink) Old 02-06-2011, 07:02 PM
Your battery will last longer if you put it on a battery tender for 5 or 6 hours, for sure. You can get it up with your 2 amp charger, though, I'd start checking it every 20 minutes after 2 hours- just to be safe.
UncleErnie is offline
post #3 of 4 (permalink) Old 03-17-2011, 09:36 AM
Newbie
I would definitely use a Battery Maintainer rather than using a full 2 Amp charger.
A battery maintainer can be found here:
http://www.bohannonbattery.com/html/...aintainer.html
Jbo24 is offline
post #4 of 4 (permalink) Old 03-24-2011, 11:44 PM
Newbie
2A charger is fine, 500mA charger will take a long time to charge.
Piranha is offline
