what did i do? - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 1 (permalink) Old 05-12-2011, 09:00 AM Thread Starter
what did i do?
i disconnected the clutch cable from the cover plate and pulled the drive sprocket cover off of my bike. A '94 vf 750 honda magna. After changing my front sprocket i put the cover on and reconneced the clutch cable. but now the clutch will not engage. I tried removing the cover again and attempted to manualy engage the clutch by poking around with the shaft that the clutch cable moves.. (i am now guessing the lifter rod?) Did i screw the pooch? thank you in advance.. AJ
pickledherring is offline
