01 gsxr 750 cutting out at wot - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 2 (permalink) Old 09-06-2011, 03:41 PM Thread Starter
yes i have a 01 gsxr 750. I am having a problems at wot wether in neutral or driving. Ive had it in 3 shops and 500$ later still have problem.The tps has ben cecked and set. The secondary butterfly valves have been removed replaced them and still runs the same.Checked the plus cyclender 1 is a little wet but looks good number 2 3 4 are white lean.Ive read hundred of threads and nothing has worked tierd of spending money at the shop. If anybody can help i would be gratefull. thanks, cj
cfilyaw85 is offline
post #2 of 2 (permalink) Old 11-05-2011, 01:09 AM
Did you ever fix your problem. If not, email me at [email protected]..
aboogie973 is offline
