Won't stay running 96 ZX7R - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 1 (permalink) Old 02-27-2012, 08:48 PM Thread Starter
ibuyvettes's Avatar
Got a ZX7R that will start up and idle but cuts off as soon as you turn the throttle, you can't even turn it a little bit, will rev up with choke engaged though but no throttle modulation. What would be the most likely problem here?
ibuyvettes is offline
