99 vz800 Suzuki charging help? - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 2 (permalink) Old 02-02-2013, 01:02 AM Thread Starter
So I'm trying to get my Suzuki in better working conditions.Right now I'm having a electrical problem. When i rev my bike the voltage in my battery goes down I'm pretty sure it doesn't go below 12 volts though. But i know it's not suppose to go down it's suppose to go up. It's been a on going issue and i just bought a new battery and a new voltage regulator. There are no known burned or corroded wires that i can see. So any suggestions would be awesome right now lol. Oh when i plugged the new voltage regulator in the bike started back firing but with the old regulator it runs fine just the voltage goes down and doesn't charge the battery.
I'm also curious does the voltage regulater need to be mounted to work properly?
Anyone have a solution for me?
NV99 is offline
post #2 of 2 (permalink) Old 02-03-2013, 10:18 PM
msgoodwrench86's Avatar
check your stator?
msgoodwrench86 is offline
