Suzuki TRE Modification More HP and throttle response? - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 15 (permalink) Old 02-15-2005, 08:33 PM Thread Starter
KillerTiller's Avatar
Question Suzuki TRE Modification More HP and throttle response?
what is this? a TRE Time Retarding Eliminator is this for real , it fools the bike into thinking it's in 6th gear so you get the full throttle response your engine actually produces in all gears ??? is this just a Suzuki thing?? I want one for my GSXR750
KillerTiller is offline
post #2 of 15 (permalink) Old 02-15-2005, 08:37 PM
Sounds pretty sweet. Do you have an article on this??
GSXR1000DJ is offline
post #3 of 15 (permalink) Old 02-15-2005, 08:38 PM
Yeah I have it on my bikes. Works awsome. I mean awsome....but get your from gixxer.com's store it is much cheaper.
post #4 of 15 (permalink) Old 02-15-2005, 09:09 PM
Like twisty said...get them from gixxer.com. you will NOT find a better price on them. they are made by a guy named jeff wallace and sold by gixxer. he even offers one with a toggle switch. also it makes the coomputer think its in 5th gear all the time. the timing retard doesnt kick in till the upper rpm range of 6th. i also hear it smoothes things out on the bottom end too like that jerking trait that busas have when cruising at low speeds.
valpoboyzkenny is offline
post #5 of 15 (permalink) Old 02-16-2005, 02:08 AM
For the michigan peeps...
You can get them for about $65 at Rec...
post #6 of 15 (permalink) Old 02-16-2005, 06:35 AM
or 30 bucks from gixxer.com
post #7 of 15 (permalink) Old 02-16-2005, 01:29 PM
OIC!! Good point... buy it from gixxer.com and send me the extra cash!! YA, that will work!!
post #8 of 15 (permalink) Old 02-16-2005, 02:27 PM
Yeah if it involves a Suzuki, I can get you the best deal.
post #9 of 15 (permalink) Old 02-16-2005, 05:01 PM
2FURYUS's Avatar
If this stops the low speed bucking on a 'busa, I'm very interested.... how difficult is it to install?
YA THINK???
2FURYUS is offline
post #10 of 15 (permalink) Old 02-16-2005, 06:36 PM
it takes 10 mins and it will stop the bucking.
post #11 of 15 (permalink) Old 02-16-2005, 07:42 PM
The TRE's are AWESOME and are as easy as plugging in your cell phone!
post #12 of 15 (permalink) Old 02-16-2005, 07:47 PM
30 bucks ???? i might get it for the sv would it be worth it to a newbie
bulldog is offline
post #13 of 15 (permalink) Old 02-16-2005, 09:02 PM
SO IS IT JUST FOR SUZUKIS OR WHAT? CAN SOMEONE TAKE THE TIME TO ELABORATE ON THIS? MY ROOMATE HAS A GSXR 1000 AND MIGHT BE INTERESTED.
post #14 of 15 (permalink) Old 02-16-2005, 09:33 PM
All a TRE (Timing Retard Eliminator) does is "fool" the CDI into thinking the bike is always in 5th gear.
On certain Suzuki models, and the Kaw ZX10R, there is a gear indicator which goes to the CDI. For each gear, there is a different ignition timing map. The maps for 1st - 4th gears have less ignition advance in lower RPMs to make the bike more "streetable" - in effect, they detune the motor so it is less responsive in lower RPMs. On the big-bore bikes, the 6th gear ignition map also acts as the speed governer by severly retarding ignition at high RPM.
With a TRE, you're always using the 5th gear map. This gives you more ignition advance at lower RPMs and no speed limit in 6th gear. That's all it does. We sell the original "Ivan's TRE" for $60 (everything else is a copy or variation of his).
The result is quicker response and more midrange power in lower gears. The downside is that it makes the throttle a bit more twitchy at the same time. It's not an optimal ignition mapping ... but for $60, it is what it is.
This is also nothing new We do the same thing with Japanese NSR250 two-stroke GP replicas. Japan had a national 47hp limit for that displacement/bike type - even though the motor will make 60 without any modification. The same basic trick works ... we fool the bike into using a lower gear ignition map that isn't restricted.
- Brian Roach
- SpeedWerks.com
SpeedWerks.com is offline
post #15 of 15 (permalink) Old 02-17-2005, 04:55 PM
2FURYUS's Avatar
Ahhh, very good info... thank you ALL.
Suprised I haven't heard of this before.
I am going to have to invest in one of these.
YA THINK???
2FURYUS is offline
