Shuts off When I pull the clutch in - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 1 (permalink) Old 11-22-2014, 10:23 AM Thread Starter
I have a 2003 Yamaha R6. Bought the bike 2 summers ago changed both sprockets, chain, air filter and oil. When the Bike is hot if its in gear and i pull the clutch in to shift the RPMs just drop and it shuts right off unless I am Revving the RPMs up. When it shuts off while rolling it will pop start itself and start right back up or i can hit the electric start and it will run but once again as soon as i put it in neutral without giving it gas it will shut right off. I put it away for the winter and after about 3 weeks of sitting I started it up and the idle was real rough till it ovately stalled which has never happened. Does anyone have any advice on this problem? Thank you, pete
peteg0719 is offline
