CBR 600 F4I gauges - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 4 (permalink) Old 03-13-2005, 10:05 PM Thread Starter
Angry CBR 600 F4I gauges
I'm having problem with my gauges. I was changing all four turn signals and when I was done my gauges and the rear running light did not work. I checked my fuse and it was blown. I replaced it and the gauges still do not work. The high beam light indicator goes on as well as the clock. The brake light will go on when brakes are applied. I have checked all connections in the front cowling and they are all good. Please help
bigdog67 is offline
post #2 of 4 (permalink) Old 03-13-2005, 11:23 PM
You probably have multiple fuses blown.... maybe another F4i guy can clarify for ya...
post #3 of 4 (permalink) Old 03-14-2005, 12:08 AM
Fuses blow because there is short. The wire from the positive terminal of the battery is being grounded by a pinched or worn wire. When you check your turn signals, you may find a wire(s) that is accidentally touching the frame (ground).
post #4 of 4 (permalink) Old 03-14-2005, 12:29 AM Thread Starter
I did look at that and then I unpluged all the turn signals and taped each one seperatly.
bigdog67 is offline
