Octane booster - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 11 (permalink) Old 03-17-2005, 11:50 AM Thread Starter
Octane booster
I've heard it's bad and can prematurely wear the rubber parts of the fuel system. True?
post #2 of 11 (permalink) Old 03-17-2005, 12:06 PM
Most all new bikes are tuned to run well on pump gas.
I don't know about bad but, I did use it on a GS 1100 street/drag bike.
I got lower ET's with it and higher ET's on race fuel.
post #3 of 11 (permalink) Old 03-17-2005, 12:18 PM
I used to use it and found out I wasn't reading the label very well. I would pour the whole thing in a 5 gallon tank that was ment for a 15-20 gallons. LOL Sure does mess things up a bit till you run it out.
GSXR1000DJ is offline
post #4 of 11 (permalink) Old 03-17-2005, 12:30 PM
Ask Gas Man - he is the resident crude oil, gasoline expert.. Don't know don't care - just know that your bike unless tuned for it doesn't need it or make use of it so why waste your money?
Mudpuppy is offline
post #5 of 11 (permalink) Old 03-17-2005, 01:38 PM
Ok ok...
First off there is a thread on a twisted version of this topic...
Octane Boost
For the most part all octane boost is, is ethynol. Ethynol is basically achohol for gasoline. Most of your gasoline branded gas at the pump have 10% in it anyway.
This is the same way Sunoco Oil makes their Ulta 94. They take the 93 and inject more ethynol into it... pushing the octane up.
Now, yes, achohol will dry out and crack some O-rings... but not really in today's vechicles. They have better material like viteen (sp?) and many others... the world of O-rings is vast. And I'm sure the manufactures take advantage of this...
Now, they some of the octane boosts do have cetane as well. Which is what the refineries use to push 87 octane up to 93... that is also what gives 93 that o, so sweet smell. AND YES, you can smell the difference between 87 and 93...
The problem is I could keep going on the subject... digest that and just ask another question...
post #6 of 11 (permalink) Old 03-17-2005, 01:45 PM
And thats why he is the Gas Man.
post #7 of 11 (permalink) Old 03-17-2005, 01:52 PM
Well one of the reasons...
post #8 of 11 (permalink) Old 03-17-2005, 02:36 PM
When they say "91 octane minimum" what would be the maximum?
r1sharknose is offline
post #9 of 11 (permalink) Old 03-17-2005, 04:55 PM
There really isn't a max persay... your bike is tuned/built for a certain octane and anything over that is a waste... does that answer your question?
post #10 of 11 (permalink) Old 03-17-2005, 06:34 PM
In that case i won't be trying any booster,thanks..
post #11 of 11 (permalink) Old 03-17-2005, 09:57 PM
Another because you need to stop sniffing it all the time.
