Speedometer nonfunctional - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 10 (permalink) Old 03-19-2005, 09:49 PM Thread Starter
The speedo on my 02 SV 650 stopped working last week. It was raining so i figgered it would dry and work again... not so. Before i start pulling things apart, what could cause this and what should i be looking for?
post #2 of 10 (permalink) Old 03-19-2005, 09:54 PM
idk but that sux!! i hope that dont happen to me
bulldog is offline
post #3 of 10 (permalink) Old 03-19-2005, 09:57 PM
Did you change anything on the bike recently?
A friend put a performance chip in his bike and it caused his gauges to go nuts.
CBR Rider is offline
post #4 of 10 (permalink) Old 03-19-2005, 10:05 PM
Check the wires on the back (plug), and the speed sensor on the motor.
unhook it and dry with electoral cleaner and relube.
Hope this helps!
post #5 of 10 (permalink) Old 03-20-2005, 12:11 AM
These guys are all on the right track...
There are a few things that could cause it... but what kind of bike is it?
Like CBR said... have you changed ANYTHING on the bike? chip, chain, SPROCKET
Second, you should have a speedo pick up on the front sprocket of the bike... you can usually get it out w/o removing too much... check it... make sure there is no damage to it... if you got something jammed up into the front sprocket and cover it could of got chewed up and spit out but not before damaging the speedo sensor.
Then check the connectors for that sensor. Make sure they're clean. Might even want to add some di-electic gel into the connector...but use it sparingly...
Also, does everything else work in your dash? If not check the connection on the back of that!
post #6 of 10 (permalink) Old 03-20-2005, 12:24 AM Thread Starter
Originally Posted by JK_DILLA
The speedo on my 02 SV 650 :
No changes were made and the tach and all the lights in the instrument cluster work.
post #7 of 10 (permalink) Old 03-20-2005, 12:31 AM
I cant remember exactly where the speed sensor is located on your bike but, you may have a bunch of lube gummed up around it.
Again check the wiring to it and it (the sensor) may need to be replaced.
Mine had 12k with no problems.
post #8 of 10 (permalink) Old 03-20-2005, 01:01 AM
I'm thinkin the speedo sensor is on the front sprocket and is either broken/damaged/ or REALLY dirty.... not too much confidence on the last idea though...
post #9 of 10 (permalink) Old 03-20-2005, 06:42 AM
It is, I've had mine off several times for work.
post #10 of 10 (permalink) Old 03-20-2005, 10:07 AM
It is what... near the front sprocket...broke...or dirty???
