Headshake solutions - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 11 (permalink) Old 04-07-2005, 10:24 PM Thread Starter
Headshake solutions
Under hard accelerating, my bike headshakes on upshifts. Nothing dramatic but enough to catch my attention.
Steering dampeners? stiffening the rear suspension? etc. what can i do to ease the problem.
post #2 of 11 (permalink) Old 04-07-2005, 10:32 PM
best thing is the steering damper
or
you could try to go a little less rebound on the front. it might help
beanz is offline
post #3 of 11 (permalink) Old 04-07-2005, 11:13 PM
dont you have a sv650s??
bulldog is offline
post #4 of 11 (permalink) Old 04-08-2005, 08:11 AM
maybe it's time to replace the bearings and do a little maint.
post #5 of 11 (permalink) Old 04-08-2005, 12:54 PM
That would be the first thing to check... then steering stabalizer...
Check my un-commom maintance thread and then do a search on steering stabalizer or dampner...
post #6 of 11 (permalink) Old 04-08-2005, 09:50 PM Thread Starter
appreciated
Thanks all, im gettin to it tomorrow.
post #7 of 11 (permalink) Old 04-09-2005, 01:46 PM
Before spending $$$ on a steering stabilizer, you may want to look into some maint and setup as mentioned above. Under normal conditions, an SV shouldn't headshake. While a steering stabilizer might keep this from happening, you're just covering up a problem, not solving it. You might want to check your sag, and make sure the rear isn't too soft. If it's squating under accelleration and unloading the front, it could cause a headshake to happen when you shift (you're unloading the rear and loading the front for a couple seconds).
- Roach
SpeedWerks.com is offline
post #8 of 11 (permalink) Old 04-09-2005, 09:48 PM
- Roach
Good advice. Don't use a damper to mask other problems...
Nine29 is offline
post #9 of 11 (permalink) Old 04-10-2005, 12:21 AM
Isn't that a basic idea of what I and Bee said???
post #10 of 11 (permalink) Old 04-10-2005, 01:44 AM
Except you didn't mention to check or stiffen the rear suspension.
Most likely the problem.
post #11 of 11 (permalink) Old 04-10-2005, 02:32 AM Thread Starter
Tomorrow Im buying a 30mm socket to get into the stering stem, but i stiffened the rear and will work that out on the way to buy the socket.
- Roach
a couple seconds?!?! I know i shift faster than that!
