Groups that require water or water wetter - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 12 (permalink) Old 05-04-2005, 08:50 PM Thread Starter
Groups that I found on the web for trackdays or racer schools that require water or water wetter. This is what I found so far.
WERA and CCS all require water or water wetter for races in their rule books.
1. STT for Intermediate/ Advanced Group
http://www.sportbiketracktime.com/po....html#bikeprep #6
2. NESBA for Advanced group.
http://www.nesba.com/Info/downloads/manual.pdf page 18
3. FASTTRAX neew racer school.
http://fastone.com/FASTTRAX/Checklist99.pdf
I'm sure there are a few more
f4ilapper is offline
post #2 of 12 (permalink) Old 05-04-2005, 09:46 PM
Good info. They won't accept Engine Ice?
post #3 of 12 (permalink) Old 05-04-2005, 10:32 PM Thread Starter
I think that most groups allow it in the novice or school groups.
Best thing is to e-mail the group that you are going to ride with and ask them up front. And have a back-up plan if someone changes their mind or if the track management steps in.
Keep in mind the whole thing is to keep slippery stuff off the track in the event of a shiny side down event. The Engine Ice is better than regular anti-freeze but it is still a little more slippery than water and won't dry up as quick.
post #4 of 12 (permalink) Old 05-05-2005, 12:32 AM
STT allows Engine Ice in the intermediate and advanced groups as well. At least they did at Putnam. It wasn't on that bike prep page, but it was on the registration form at the track. They allowed anything in novice, but you had to use water, water wetter, or engine ice for intermediate or advanced. I made sure of that before hand because I had Engine Ice and I thought I would be moving up to intermediate the second day. But, since you do a lot of track days with different groups, it would definitly be a good idea to just go the all accepted route.
post #5 of 12 (permalink) Old 05-05-2005, 12:38 AM
My bikes have never been checked.
For all they know, they could have old fashioned antifreeze in them.
They always just ask what coolant I'm using and leave it at that.
Pleas for me and other riders.
Comply with the rules.
post #6 of 12 (permalink) Old 05-05-2005, 03:11 AM
Consider it complied with.
post #7 of 12 (permalink) Old 05-05-2005, 08:31 AM
usually if you crash and spill antifreeze all over the place you will get a nice fine for the clean up, at least thats the way it is at loudon and the LRRS,,,,(plus all the other racer/riders are gonna be real pissed with the delay its gonna take to clean it up)........so i imagine it would be the same at other tracks...fine use to be $250.00, not sure what it is now.....
GsxrJack is offline
post #8 of 12 (permalink) Old 05-09-2005, 08:25 AM
I would say just don't be a tool. Run the approved coolant. Are you really getting over on anyone by running anti-freeze?? It costs a metric fortune to go the track when you add everything up. What's another couple dollars and hour of your time to change the coolant?? Just my
CBR Rider is offline
post #9 of 12 (permalink) Old 05-09-2005, 10:08 AM
You're actually getting less cooling if you run anti-freeze.
Plain water would be the best, but it's very corrosive. Anti-freeze is basically there for two-reasons - freezing, and corrosion. Water wetter acts as an anti-corrosive and actually cools the bike much better because you've got more water in the system than you do with a normal water/anti-freeze mix (you only use 4 oz of water wetter to the gallon of water). They also claim it changes the surface tension of water to improve heat transfer, but I'm not a chemist so I can't comment to much on that aspect
- Roach
SpeedWerks.com is offline
post #10 of 12 (permalink) Old 05-09-2005, 01:19 PM
I just received an e-mail from Monte (STT) regarding their website and the allowed coolants. Here was my e-mail to him:
Monte,
I see that the STT website states that only water or water wetter is allowed in intermediate and advanced. However, when I was at Putnam Park, the registration form stated that Engine Ice was allowed as well. Is Engine Ice allowed at Mid Ohio?
Thanks,
Avery
And here is Monte's response:
Good eye!! Our fault. We need to change the website. Engine Ice, 7th Gear, Evans and Liquid Performance are all ok.
Monte
post #11 of 12 (permalink) Old 05-09-2005, 01:41 PM Thread Starter
Excellent research Captin' now we have 3 more options. So as long as your local bike shop carries at least one brand you should be good to go.
Rob
http://www.evanscooling.com/main27.htm
http://www.lpmx.com/
Couldn't find a webpage for 7th Gear directly.
post #12 of 12 (permalink) Old 05-10-2005, 01:33 AM
I would guess that all track would except these if actually asked.
