My bike is really dirty... - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 21 (permalink) Old 06-07-2005, 04:41 PM Thread Starter
As most of you know, I just bought my zx6r off of an idiot who cant wheelie and laid it down. Oil everywhere! (see pictures below) Basically my question is: What is a good method or product for removing "gunk" and oil off plastics? All the mess is inside the fairings. All i have done is scrape off the major chunks with a spatula and it took off the top layer pretty good. Anybody know of any "de-greasers" that remove that nasty black sludge and motor oil really well?
ID:	3404   Click image for larger version
Name:	all that oil.JPG
snadamo is offline
post #2 of 21 (permalink) Old 06-07-2005, 04:49 PM
take it to a car was with a pressure washer. i always use it and ppl always ask me if i clean my bike all they time casue it gets real clean, but mine also has degreaser that runs through it. and also watch out casue soem degreasers will discolor stuff.
btw what replacement stator cover are you gonna get?
zx636r is offline
post #3 of 21 (permalink) Old 06-07-2005, 04:57 PM Thread Starter
Luckily the old man just bought a bunch of stuff for his garage and Vette, including a pressure washer! Ill have to head on over there and give the ninja a good pressure wash.
I already got the new one and put it on. Its just a brand new Magnesium OEM stator cover. cost about $80. Not too bad, but i probably could have shopped around and got a better price. Ill have pics soon of the "rebuild" BTW still want to give those turn signals away?
snadamo is offline
post #4 of 21 (permalink) Old 06-07-2005, 04:59 PM
there is no giving but they can be sold cheaper then u will find them. lol
zx636r is offline
post #5 of 21 (permalink) Old 06-07-2005, 05:01 PM Thread Starter
name your price for fronts and rears. Maybe we can work something out
snadamo is offline
post #6 of 21 (permalink) Old 06-07-2005, 11:50 PM
I would suggest that you DO NOT use a high pressure sprayer on your bike! You can seriously F stuff up with that!!!!!
Also, get some hi-temp gasket sealer, the stuff you use on head gaskets and stuff, you can get it at any auto shop. You are going to need some when you replace that stator cover.
Any auto degreaser should work on that grime. Just get it at the auto store when you buy the gasket maker stuff. I have a Castrol brand stuff, it's in a purple spray bottle. I use that on my rims and to get stuburn bugs off. It works well and hasn't given me any paint problems!
post #7 of 21 (permalink) Old 06-09-2005, 01:16 PM Thread Starter
Sawweet!
Ill have to check that out After she gets back from the shop
snadamo is offline
post #8 of 21 (permalink) Old 06-09-2005, 02:56 PM
Maybe "Goo Gone" will work?
Samurai_Jack is offline
post #9 of 21 (permalink) Old 06-09-2005, 03:11 PM
Originally Posted by Gas Man
I
I used some for my clutch cover. I took it off, replaced the O-Ring and it still leaked oil. I gooped it up with gasket sealer and no-mo problems.
post #10 of 21 (permalink) Old 06-09-2005, 04:47 PM
One of my favorite garage helpers is "goof off". It is really good at removing oil/grease. It is fairly non-toxic. Available at home-depot.
carlmorrell is offline
post #11 of 21 (permalink) Old 06-09-2005, 05:11 PM
Be careful of Simple Green degreaser. It can be harmful to your paint. I have seen it eff up Suzuki wheels and dull the finish. Dont ask me how it happened, it just did. It also dulled the finish on some stock aluminum Jeep wheels.
Goof-Off stained the lower fairing on my RC51, it actually got into the catch pan area and worked its way into the paint. Just my experience.
The organic Orange Blast-RocketFuel type cleaners have worked for me.
That Castrol stuff mentioned works good too!
WarpedRotor is offline
post #12 of 21 (permalink) Old 06-10-2005, 12:06 AM
That stuff is a must have...
So is Goo-Gone. It's good stuff!
post #13 of 21 (permalink) Old 06-10-2005, 09:29 AM Thread Starter
Does that stuff you deemed "paint eating" go all the way through the fairing? Because for me, I would be cleaning the inside of the fairings just so it doesnt periodically leak oil on the floor. Ive been leaning both fairings up against the wall with cardboard under them just to drain until I figure out what to do.
snadamo is offline
post #14 of 21 (permalink) Old 06-10-2005, 03:16 PM
i use a pressure washer on my bike all the time, no way in he!! im gonna try and get all the bugs off by hand and scratch the piss out of my bike. use the pressure washer for your plastic and wheels and then just wash the rest by hand.
but yes u can screw stuff up with a pressure washer.
zx636r is offline
post #15 of 21 (permalink) Old 06-10-2005, 11:01 PM
Just be carefull! A pressure sprayer can chew threw drywall, vynal siding, wood, paint, plastic, and much more. Of coarse this is for a good pressure sprayer. The one I use is like a 2500 or 3000 psi... ya know a nice one with a 6hp Briggs n straton.
But anyway, my point is that you don't want to go blastin off paint, or chew thru gaskets on your motor or whatever...there is so many bad things you can do with one of those!
post #16 of 21 (permalink) Old 06-11-2005, 12:49 AM Thread Starter
Yea the plan was just to take off the plastics, and wash the inside of the plastics. not gonna touch the motor, guages, seat, the air intake vents, and the inside of the muffler (cause it gets really dirty in there, too). power spraying is good for brute force. More delicate detailed work requires human hands. But I could see some 'tard power washing his entire bike...
snadamo is offline
post #17 of 21 (permalink) Old 06-11-2005, 10:14 AM
Yep, then you understand!
post #18 of 21 (permalink) Old 06-11-2005, 10:54 PM
Sime's Avatar
You can also try liquid dawn dishwashing liquid, with very hot water (but not boiling). Use gloves. Dawn breaks down grease, and the hot water really helps too.
Many years ago, I used to be a prestige car detailer. We had a kerosene heated pressure washer that we used to degrease the engines. The heated water was the only way to effectively 'steam clean' the motor. Cold water was pretty much useless.
Any Aussies that want your bike painted.....give me a holler! www.paintwerks.com.au
Sime is offline
post #19 of 21 (permalink) Old 06-12-2005, 07:38 AM
The hot water trick always works well!
post #20 of 21 (permalink) Old 06-12-2005, 10:09 PM Thread Starter
Funny, a buddy of mine mentioned using Dawn and hot water today...
Is that you Bob?
j/k thanks for the tips. Ill give her a whirl soon. My bike is in the shop. Once its out, ill try the Dawn and hot water. Thanks guys!
snadamo is offline
