Downshifting Problem? - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 29 (permalink) Old 06-13-2005, 08:28 PM Thread Starter
At a recent trackday I was encountering a a strange feeling during a heavy downshift from 3rd to 2nd gear. I was downshifting at around 12000 rpm and going into 2nd from 3rd for a tight 160 degree turn (The bus stop at Grattan). Within a few seconds after the downshift the engine rev'd a little higher just like another downshift. It was not consistent with every lap only twice during the day. The F4i is an '03 with just over 6,000 miles, stock chain and sprockets, and standard tire sizes. I change oil before each trackday weekend with the HP4 synthetic blend 10W-40. Any ideas on what may be wrong if anything. TIA
Rob
f4ilapper is offline
post #2 of 29 (permalink) Old 06-13-2005, 09:43 PM
So you were @ 12ooorpms in 3rd and kicked her is 2nd?
post #3 of 29 (permalink) Old 06-13-2005, 09:48 PM
Is the tire or clutch slipping?
post #4 of 29 (permalink) Old 06-13-2005, 10:03 PM Thread Starter
Twisty, It is just before it hits the rev limiter in second. When is drops into second it is at 12000-13000 rpms.
Jeeps, I thought it was the tire slipping the first time but it is very smooth and did not give the weave that you get when the tire spins.
TIA
post #5 of 29 (permalink) Old 06-13-2005, 10:42 PM
It may be time for a new clutch!
post #6 of 29 (permalink) Old 06-13-2005, 10:47 PM
6,000 miles on a clutch, that would suck!
post #7 of 29 (permalink) Old 06-13-2005, 10:59 PM
Track days can be brutal on a bike!
post #8 of 29 (permalink) Old 06-13-2005, 11:06 PM Thread Starter
About 60-70% of the miles are on the track. Has anyone installed or used a Barnett Clutch Kit. Is it worth the $120.
http://www.indysuperbike.com/custome...t=26199&page=1
post #9 of 29 (permalink) Old 06-13-2005, 11:12 PM
They make a clutch for the SV SWEET!!!!!!!!!!!!!!!! and its only $82.00 I should buy it just so I have a new clutch for when I need it! I wonder if I could put a new clutch in my self. anyone know?
post #10 of 29 (permalink) Old 06-13-2005, 11:12 PM
Not on a bike like yours but I have never had on either.
Barnett is quality stuff.
The spring will be a lot stiffer.
Not to worry on a track bike but a daily rider could be tough.
post #11 of 29 (permalink) Old 06-13-2005, 11:15 PM
I like stock clutches the best, a little more money but worth it imo...ive had bad luck with barnett clutches..I fried their kevlar clutch when it first came out after 3 runs on my gsxr11 with nos at the drag strip...never had a problem with stock clutches...
GsxrJack is offline
post #12 of 29 (permalink) Old 06-13-2005, 11:17 PM
any clutch suggestions for the SV. I don't need one yet, I've got 17,000 hard miles on the original clutch, and clutch wheelies on the time.
post #13 of 29 (permalink) Old 06-13-2005, 11:17 PM
Its pretty simple.
If you can take something apart and put it back together and it still work, than I would say yes.
Keep everything in order on dissemble and reinstall with new stuff in reverse order.
If your unsure. Enlist the help of somebody that is sure.
post #14 of 29 (permalink) Old 06-13-2005, 11:18 PM
If it aint broke, don't fix it.
post #15 of 29 (permalink) Old 06-13-2005, 11:20 PM
I just thought about buying one so I'd have it when it does go, but oh well. I hate fixing something till its broke!
post #16 of 29 (permalink) Old 06-13-2005, 11:21 PM
6000 miles, i was happy when i got 600 miles out of my clutches....
GsxrJack is offline
post #17 of 29 (permalink) Old 06-13-2005, 11:22 PM
Its pretty simple.
I'm pretty mechanically inclined so I'd say I could do it.
post #18 of 29 (permalink) Old 06-13-2005, 11:22 PM
OUCH!!!
post #19 of 29 (permalink) Old 06-13-2005, 11:24 PM
I have had better luck with oem clutches also.
It will let you know usually with enough time to order a set before its gone all the way.
post #20 of 29 (permalink) Old 06-13-2005, 11:26 PM
OUCH!!!
ya, good thing was i got all my parts for 10% over dealer cost so instead of around 180.00 for a clutch pack it cost me around 80 or so....
GsxrJack is offline
