Oil question..another one. :) - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 13 (permalink) Old 06-14-2005, 02:22 PM Thread Starter
My 2005 ZX6R calls for 10w40. The average air temps I will see are between 84-94 degrees F. Is this what everone recommends, or should I try something a little different? Also what are everyone's thought's on the best milage to switch to full synthetic, or should I?
HISSMAN is offline
post #2 of 13 (permalink) Old 06-14-2005, 02:25 PM
I put Pennz 10W40 in the bee...just make sure it does not say energy conserving on the label...look on the back for the circle with the grade letters and numbers. Of course, I change my oil every 6 weeks...probably why it is having open head surgery today...
post #3 of 13 (permalink) Old 06-14-2005, 02:29 PM
Hopefully not a sex change too
snakemann is offline
post #4 of 13 (permalink) Old 06-14-2005, 02:44 PM
depending on what they tell me...it could end up being a brand change...
post #5 of 13 (permalink) Old 06-14-2005, 09:38 PM
If you're concerned about it...go with full sync. I suggest Amsoil but that's just my
post #6 of 13 (permalink) Old 06-14-2005, 10:09 PM Thread Starter
When is the best time to switch to a synthetic? I want to make sure that I don't mess with the break in process. So I guess the standard 10w40 would be the best thing to go with, and not a 20w40, or a 10w50 per-say?
HISSMAN is offline
post #7 of 13 (permalink) Old 06-14-2005, 10:17 PM
Stay with the 10w-40 because your motor is designed for that and the passages are designed for that weight oil as well. I would definately stick with convential thru at least a few thousand miles...but this is a question of the ages!
post #8 of 13 (permalink) Old 06-15-2005, 12:26 AM
I've read that you shouldn't use synthetic oil until the bike has 5,000 miles.
post #9 of 13 (permalink) Old 06-15-2005, 08:06 AM
Like I said a few thousand miles... I didn't use it on my 9R until like 6 or 7 thousand!
post #10 of 13 (permalink) Old 06-15-2005, 09:57 AM
EIDROEDYR's Avatar
I'll be changing over to Amsoil at my next oil change. I currently have 3400 miles on the clock. I anticipate my next oil change at about 4700. Also, they now carry Amsoil at Murray's auto parts but better pricing can be had online.
EIDROEDYR is offline
post #11 of 13 (permalink) Old 06-15-2005, 10:24 AM
I run Amsoil in all my bikes... From Zero miles.
post #12 of 13 (permalink) Old 06-15-2005, 01:38 PM
At Murray's? Really? Even the MC version of the oil? Which is very important!
post #13 of 13 (permalink) Old 06-15-2005, 04:50 PM Thread Starter
Very good info in this thread.
Thanks.
HISSMAN is offline
