Radiator Flush - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 11 (permalink) Old 06-26-2005, 07:02 PM Thread Starter
Radiator Flush
So I decide to flush my cooling system today. Half hour to strip off the plastics. I read the manual and start to take out the drain bolt at the water pump. With a big bucket ready, I take out the bolt. Green fluid is slowly dribbling out. I decide to take off the radiator cap which is on the other side of the bike. When I do, the fluid shots out the hole three feet, completely missing the bucket. But the fluid stream doesn't miss my Haynes manual which is just two feet away.
I put in some Zerex flush. Says it is safe for aluminum. The label says to drive the vehicle for three hours. Wife doesn't believe it until I show her the label. Yahoo. I come back to the garage, drain and flush the Zerex and add Prestone, which it says is safe for aluminum and contains no silica. I'll test it next week.
Here's a picture of my CBR without side plastic. Looks like a Hooligan bike.
Name:	hooligan bike1.jpg
post #2 of 11 (permalink) Old 06-26-2005, 07:08 PM
WOW look at that exhaust! Is that a shroud?.. because it is large till it goes under the motor.
post #3 of 11 (permalink) Old 06-26-2005, 07:14 PM Thread Starter
Shroud. Covers the junction where the four pipes go to two to one and back to two.
post #4 of 11 (permalink) Old 06-27-2005, 01:50 AM
Always take the cap off first.
If you hung the book up on a line with binding on top. It would dry and still be able to read most pages.
post #5 of 11 (permalink) Old 06-27-2005, 01:54 AM
Grafixx01's Avatar
How old is that bike? Looks like an early 90's - late 80's model?
Grafixx01 is offline
post #6 of 11 (permalink) Old 06-27-2005, 04:46 AM
That's a Hurricane. Before the F2.
post #7 of 11 (permalink) Old 06-27-2005, 11:57 AM
Sorry about the mishap No Worries.
I pulled my cables off my bike, using a string to trace the weird path they take and while I was across the garage cleaning and lubing them up, my Belgian Malinois started sniffing the strings. I yelled, "Hey!" and his response was to grab the string ends and run Took me some time to find out the routing again
kanwisch is offline
post #8 of 11 (permalink) Old 06-27-2005, 08:13 PM
i thought Hurricanes were V4's. What was the V4 bike called?
post #9 of 11 (permalink) Old 06-27-2005, 10:00 PM Thread Starter
The Honda V4 cruiser was the Magna, V4 standard was the Sabre, while the V4 sport was/is the Interceptor or VR4.
The Honda Hurricanes were in 87-88 in 600 and 1000 cc's. Got bigger tires and wheels, and different fairing in 90-91 and were just called CBR's. The 1000's got linked brakes for 93-96, and were replaced by the Blackbird in 97. The 600's were F2, F3, F4, F4i.
post #10 of 11 (permalink) Old 06-27-2005, 10:04 PM
I must be thinking of old VR4's... i'll go look at bikepics.com yup youre right.
post #11 of 11 (permalink) Old 06-27-2005, 10:37 PM
*cough* VFR *cough*
