Something is wrong with my front wheel... - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 7 (permalink) Old 06-26-2005, 07:22 PM Thread Starter
KillerTiller's Avatar
just finished washing my bike so i put it up on stands and when i went to polish my front wheel and spun it around it made a funny noise ...It doesn't make the noise all the way around when i spin the wheel just in a specific spot it actually sounds like one of those indoor waterfalls it makes that crickling sound like a babbling brook.....what the hell is it my bearings????
KillerTiller is offline
post #2 of 7 (permalink) Old 06-26-2005, 08:07 PM
That what is sounds like to me. I had a bearing go bad on my TL and thats kinda what it sounded like. Pull the wheel off and grease the axle and bearing real good and then check it.
post #3 of 7 (permalink) Old 06-27-2005, 01:45 AM
Just a thought, have you checked the pads?
It does sound like a bearing.
post #4 of 7 (permalink) Old 06-27-2005, 12:31 PM
I agree with both of you.... my first thought was the brakes..but a bearing could be the problem. Either way, pull the front wheel, check both and go from there!
post #5 of 7 (permalink) Old 06-27-2005, 12:43 PM
check the pads and rotor first, then the wheel bearing...
post #6 of 7 (permalink) Old 06-27-2005, 07:06 PM Thread Starter
Thanks Guys will do...........i should stop riding my bike the way it is until i get it repaired.......
post #7 of 7 (permalink) Old 06-27-2005, 10:40 PM
Good idea!
