New Tire - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 14 (permalink) Old 07-04-2005, 02:09 PM Thread Starter
New Tire
Hi guys Its time for a new rear tire. My current tire is a 180-55-17 and I'm wanting to put a 190-50-17 on instead. I have about 1/4 inch between the chain and my 180. DO you guy's think this is going to work. thankx guys flipmo
flipmo is offline
post #2 of 14 (permalink) Old 07-04-2005, 05:15 PM
What is the bike, year, and other good info???
Also, what do you plan on getting with the larger tire?
Is it just for the appearance of more rubber out the back?
post #3 of 14 (permalink) Old 07-04-2005, 07:42 PM
BusaBabe's Avatar
Yeh post more info and I can ask the guys at the shop this week.
BusaBabe is offline
post #4 of 14 (permalink) Old 07-04-2005, 07:58 PM
Huumm, i usually go the other way(bigger to smaller), but thats me.
Your bike is going to turn slower and feel fatter. So in short it will make you wish you kept a 180 on it.
post #5 of 14 (permalink) Old 07-04-2005, 09:54 PM Thread Starter
The bike is a 95 gsxr750 Its my drag bike.
flipmo is offline
post #6 of 14 (permalink) Old 07-04-2005, 11:28 PM
For drag racing purposes only, you should be OK with a wider tire but I don't recommend it for the street. The real thing you want to look for (assuming you want a larger footprint for more traction) is the profile of the tire. For example, a Continental tire has a much flatter profile which would do well in a straight line. However, if you are looking for traction, you would have to consider the Dunlop 218 GP because it has the softest and stickiest rubber, but it is also expensive.
post #7 of 14 (permalink) Old 07-05-2005, 01:30 AM
but we are just knee dragers.
Larry knows best!
post #8 of 14 (permalink) Old 07-05-2005, 05:53 AM Thread Starter
That really still does't answer my question. I have a 1/4 of an inch between the chain and my 180 can I fit a 190. And yes I do ride this bike on the street and have no problems.thanks guys flipmo
flipmo is offline
post #9 of 14 (permalink) Old 07-05-2005, 08:39 PM
Well...you are talking about a tire that is nominally 10mm wider than the one on it. With 25.4mm/inch you would have roughly 1.35mm clearance left on that side...seems kinda close to me but it also doesn't take into account that you are using the same width rim and that will affect how much the wider tire actually sticks out. Of course, that also doesn't take into account that different tire manufacturers have different shoulder designs that affect clearance as well. FWIW, you are talking about a minor increase in width for a potentially major PITA...
post #10 of 14 (permalink) Old 07-06-2005, 09:08 AM
Good point there Larry!
post #11 of 14 (permalink) Old 07-06-2005, 09:35 AM
Nice to have Larry posting that good info again... On a side note...I only refer to the ones who do, as stealerships...
post #12 of 14 (permalink) Old 07-06-2005, 09:39 AM
with Larry, and Twisty. I was going to move up to a 170-60-ZR17 on the SV, but I was told to keep the 160-60 on for better knee dragging. Now that I am at that point, I am so glad I listened to the guys at the shop.
post #13 of 14 (permalink) Old 07-06-2005, 02:48 PM
I would also take into account that when dragracing you should lower the rear tire air pressure and thats gonna flatten it out a bit more. so i would take that into the equation also.......
if your worried about getting a bigger tire for dragracing purposes...unless your bike has an extended swingarm you really shouldnt have traction problems with a gsxr750...I had a 93 gsxr750 with stock arm and the only problem i had was with the bike wanting to head for the sky, was the hardest bike i ever tried to launch, (that and i had it geared like a baastard, down one in the front sprocket and up 3 in the rear sprocket, which didnt help, but the bike was feeble under the powerband)...it was hard bike to launch and loved to eat clutches, but i never had a traction problem with a stock arm on anything under a 1000 cc's
GsxrJack is offline
post #14 of 14 (permalink) Old 07-07-2005, 10:12 AM
I agree with Jack... the gains in the little bit larger tire doesn't out weight the possible PITA!
