Brakes aren't feeling so good - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 7 (permalink) Old 07-09-2005, 03:09 PM Thread Starter
I dialed the brake lever down to "1" and the lever travel is still too much; it's practically to the grip. I need all the leverage I can to get the front stopped. It DOES stop fine, but with too much effort.
There are no leaks, the reservoir is full... I don't get it. Why all of the sudden?
I bled the system about 2.5 years ago, is it time to do it again?
'99 SV650S for those that don't know...
post #2 of 7 (permalink) Old 07-09-2005, 03:27 PM
not only time to rebleed the brakes but to change the fluid also.....
GsxrJack is offline
post #3 of 7 (permalink) Old 07-09-2005, 03:53 PM
I try and change the fluid every spring, while others say you only need to do it every 2 years. Either way, yeah its definately time shan.
Need4Speed is offline
post #4 of 7 (permalink) Old 07-09-2005, 04:08 PM
Check the pads first. Then change fluid and bleed.
post #5 of 7 (permalink) Old 07-09-2005, 09:00 PM
Pads wont make the brakes soft. The fluid needs to changed and bleed. I'm having the same issue in the 1k and but I desided to put the same Carbone Lorraine brake system I have on my Race bike on the 1k for the extra stopping power. Its cheaper than the brembo and works just as well.
post #6 of 7 (permalink) Old 07-09-2005, 11:19 PM
This is also a good time to consider braided steel lines if you don't already have them.
post #7 of 7 (permalink) Old 07-10-2005, 02:14 PM
Twisty is right... it's not the pads... however, if you're going to pay attention to the brakes check those while you're down there!
Some steel braided lines would help too! i would change out the fluid either way. Make sure you bleed the caliper, the brake lines, and the banjo bolt!
I just recently did a fluid change on my bike...do it every year.... and got some air in the caliper. Had to take them off, pump the brakes till they were out almost all the way, then bleed them backwards thru the bleeder bolt. BAM, they got nice and hard again!
