gsxr 600 shuts off - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 18 (permalink) Old 07-09-2005, 05:37 PM Thread Starter
gsxr 600 shuts off
I have a 98 gsxr 600 srad. It starts up fine. After i ride it for about 20 or 30 mins. it starts to lose power and then shuts off. after a few mins i can start it right back up. it runs very well while it is running so i dont' know what would make it cut off.
kikwearsk8er is offline
post #2 of 18 (permalink) Old 07-09-2005, 08:14 PM
I'm betting your fuel tank isn't venting properly. When it cuts out, open the fuel cap - I bet you hear a big sucking sound.
If that's the case ... I *think* that year vents through the cap, but I can't remember without looking at it - remove the cap and blow it out with air. It may have a vent line on the bottom of the tank, you need to make sure it isn't pinched.
- Roach
SpeedWerks.com is offline
post #3 of 18 (permalink) Old 07-11-2005, 04:09 PM Thread Starter
thanks for the info i'll listen for the sound. i just got everything painted could it have been painted over or filled with gunk
post #4 of 18 (permalink) Old 07-11-2005, 09:35 PM
Even more likely that is your issue...
post #5 of 18 (permalink) Old 07-11-2005, 09:47 PM
also check your fuel line, it could be pinched.
post #6 of 18 (permalink) Old 07-11-2005, 10:36 PM Thread Starter
i pulled out the gas cap and think i found the vent i can folow a hole in the tank itsself to a hole in the bottom of the cap. all the holes it wnet through where clear. my fuel line doesn't look pinched. i went to ride it today adn my ignition fuse blew. i changed it and now i can't even get it to start.
post #7 of 18 (permalink) Old 07-11-2005, 10:47 PM
Since you changed the fuse, is it even cranking over? Did you unplug any electrical wires when you took the fairings off to paint the bike? There is something wrong electrical wise if that ignition fuse blew. That just shouldn't blow. Somethings got to be shorting out. Run down the electrical wires make shure a wire isn't stretched, pulled, loose from the regulator box, all the way to the battery. Just look over it real close is the best advice I can give now.
post #8 of 18 (permalink) Old 07-11-2005, 10:49 PM Thread Starter
ok i'll do that after work tomorrow. it sux i only get like an hour or two of day light when i get off work so i can't do much in a day
post #9 of 18 (permalink) Old 07-11-2005, 10:54 PM
I feel your pain there. I live in an apartment now, I'm not even allowed to change my oil here, and its so hot outside from 3:30 when I get off work until 8 or so. Then there is no time to even tear the bike down to work on it. I guess my best advantage is I have bay doors in the warehouse at work I can just pull the bike in to work on it. However I am limited on time there too before the alarm sets otherwise I have to deal with ADT. After being at work from 7 to 3:30 I really don't want to be there anymore.
post #10 of 18 (permalink) Old 07-12-2005, 06:29 PM Thread Starter
could someone point me in the direction of a wireing diagram. the guy i got this bike from did a really bad job with maintaining the wires
post #11 of 18 (permalink) Old 07-12-2005, 07:58 PM
Do you have a service manual? Mine has my bike entire diagram or schematics in there. Thats my only knowledge of easily finding it.
post #12 of 18 (permalink) Old 07-12-2005, 08:58 PM Thread Starter
no i dont have it
post #13 of 18 (permalink) Old 07-12-2005, 09:00 PM
no i dont have it
I'd recommend getting one its always a good thing to have. Have you seen any unusal wear, tears or anything in the wireing?
post #14 of 18 (permalink) Old 07-12-2005, 10:20 PM
I can't add much to the wiring problem, but I can't see that being the cause of your first problem. Electrical problems tend to be on or off, and if they're intermittant, they're constantly intermittant (if that makes sense).
I've seen a similar problem to your fuel issues. More than likely your fuel tank has a "tap" that has a vacuum activation, i.e. a small hose from the valve to the intake manifold. I saw this on an old VFR400, which would run for about 15 mins, then die. Once you left it for an hour or so, it would start again, only to stop about 15 mins later again. The fuel tap had 2 identical "nipples" which the manifold vacuum hose would fit on. One was the right one, the other was just a breather. Any guesses which this one was on? The reason it would start is that fuel was leaking past the tap and filling the fuel bowls, but would cut out after the bowls emptied.
If your bike's injected, disregard all of the above, check power to fuel pump when hot!
Good luck
Chuckademus is offline
post #15 of 18 (permalink) Old 07-12-2005, 10:24 PM
Good luck
this could be BabyNinja's problem with her "tried almost everything" thread. I remember her asking how to clean the tank and marbles or something along that line.
post #16 of 18 (permalink) Old 07-13-2005, 12:58 PM Thread Starter
thanks aain for all the help. i took yesterday off and sat down and when through all my wireing. i replaced wires that where bad and i re connected some wires that where riped out of a harness. everythign works great now. i really apprecate the help.
post #17 of 18 (permalink) Old 07-13-2005, 01:28 PM
Ahh ha! Glad I could be a help to ya. I figured it was something electrical since you blew the fuse. That's my specialty (electrical)
post #18 of 18 (permalink) Old 07-13-2005, 07:38 PM Thread Starter
it was great to have a full day to work on it.
