Pipe Packing Question - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 35 (permalink) Old 07-13-2005, 06:24 PM Thread Starter
My repack kit came in and I plan on stuffing it tonight. Anything i should know before I tackle this? Luckily my pipe doesn't have rivets so I don't need any of that. I think mine is ready to go out of the bag but i know some just come with the materials and you have to wrap it your self. Just wondering. TIA
post #2 of 35 (permalink) Old 07-13-2005, 06:45 PM
My old Suzuki triple had four pipes that needed repacking. Since it was a two-stroke, I used a propane torch to burn off the carbon, wrapped the fiberglass around the baffle, and used stainless wire to wrap around the fiberglass. I used regular fiberglass, but I think they make special fiberglass for this now.
post #3 of 35 (permalink) Old 07-13-2005, 06:51 PM Thread Starter
Not even sure if there is fiberglass in mine. The picture shows it in a bag so I'm hoping it's wrapped and ready but we'll see tonight I guess.
post #4 of 35 (permalink) Old 07-13-2005, 09:20 PM
wear gloves
post #5 of 35 (permalink) Old 07-14-2005, 01:02 AM
Your pipe will be quiter when you're done!
post #6 of 35 (permalink) Old 07-14-2005, 01:32 AM
Lots quieter!
Its tuff to get it stuffed back into the can. Use some wire to keep it tight!
post #7 of 35 (permalink) Old 07-14-2005, 10:37 AM
Originally Posted by jeeps84
Lots quieter!
Masking tape. You wrap the packing around the baffle then use masking tape around the outside. Stuff everything back in the sleeve and put the end cap back on.
- Roach
SpeedWerks.com is offline
post #8 of 35 (permalink) Old 07-14-2005, 12:17 PM Thread Starter
I did it yesterday and it was REAL easy. GYT-R has everything all wrapped and ready to go around the core. No tape, no nothing. The cover slipped back on with ease as well. However, I do have a lot of fiberglass splinters. The pipe is just as loud and it seems like the bike is more responsive now. Just throttle anyway. Haven't rode it yet. it was 114 outside yesterday.
post #9 of 35 (permalink) Old 07-14-2005, 12:36 PM Thread Starter
This just in. Duct tape works for fiberglass splinters.
post #10 of 35 (permalink) Old 07-14-2005, 01:16 PM
Cold water as well - it causes your pores/skin to close/tighten up and will push the fiberglass out. Works after doing work in your attic as well.
- Roach
post #11 of 35 (permalink) Old 07-14-2005, 01:21 PM Thread Starter
Cool!
post #12 of 35 (permalink) Old 07-14-2005, 01:24 PM
The packing must not have need to be replaced!
Glad it went well!
post #13 of 35 (permalink) Old 07-14-2005, 01:31 PM Thread Starter
I had about 10K on that packing. It was pretty dirty. Maybe it was cuz
I was in my garage and it was echoing.
post #14 of 35 (permalink) Old 07-14-2005, 01:32 PM
Its going to get dirty. I bet if you take it out after only a few miles the new will look the same.
post #15 of 35 (permalink) Old 07-14-2005, 01:38 PM Thread Starter
All I know is that it made a difference. And it was only 25 bucks.
post #16 of 35 (permalink) Old 07-14-2005, 01:39 PM
post #17 of 35 (permalink) Old 07-14-2005, 02:15 PM
I wonder if I should do mine... mine has like 14K on it....
post #18 of 35 (permalink) Old 07-14-2005, 02:23 PM
OK Micron wants $35 for the packing... where else are you suppose to order this stuff from?
post #19 of 35 (permalink) Old 07-14-2005, 02:25 PM Thread Starter
Try a dealer or a bike shop. My dealer carried mine.
post #20 of 35 (permalink) Old 07-14-2005, 05:35 PM
I called the only dealer type place (rec) that I order that stuff from and they said they have aftermarket stuff not but the Micron stuff. If I wanted the Micron stuff they would have to order from Micron. But heck I can do that...
