what lights your fire - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 8 (permalink) Old 07-15-2005, 05:32 PM Thread Starter
Sparkplugs, sparkplugs... whats your prefrence. Iridium, platnum, OE? Im on an SV so any SV specific experience is welcome. Im putting together a shopping list so if you know of any good ignition wires, coil, etc. too.
thanks, jesse
post #2 of 8 (permalink) Old 07-15-2005, 05:36 PM
I had problems after the stage 3 jet kit, K&N, and full yoshi race exhaust were installed. I raised the question to the suzuki shop, when my plugs kept gett fauled out, they asked me what mods I have so I told him. He said Oh [email protected], I know what it is...you need to run a "hotter" plug. Its been almost 2 years since I have replaced those plugs but I still don't have ANY problems what so ever with them. I can't remember what the model was, but I know it is a NGK plug.
post #3 of 8 (permalink) Old 07-15-2005, 06:15 PM
oem blows thats all i can tellya i thought ngk was good no????
TL1000 is offline
post #4 of 8 (permalink) Old 07-15-2005, 09:40 PM
NGK is fine...if you are fouling plugs, you need to be tuned properly. Installing a hotter plug just masks the real problem.
Now, on my modded WRX I run one step colder plugs and I use the ND Irridiums...
post #5 of 8 (permalink) Old 07-15-2005, 09:54 PM
I use the standard NGK plug that Honda recommends, but I use the non-resistor type (DP9EA-9 instead of DPR9EA-9). Non resistor plugs give a hotter, but shorter spark than standard resistor plug. I also took out the resistor in the spark plug wires.
post #6 of 8 (permalink) Old 07-15-2005, 10:02 PM
All I know is the bike fires right up after 1 crank cold and 1/2 crank hot, after 2 years of the same NGK plug I don't know if there ever was a problem, but these NGK's are great.
post #7 of 8 (permalink) Old 07-15-2005, 10:41 PM
NGK Iridium all the way!! I noticed a little difference with them. They fire like 30% more accurately than platinium.
post #8 of 8 (permalink) Old 07-15-2005, 10:45 PM
I think that's what I have GM.
