CBR600 f4i starting problem - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 9 (permalink) Old 07-17-2005, 04:57 PM Thread Starter
I found some good info searching, but it didnt help.
My problem is this:
the bike will run while its cranking only. As soon as i let off the start button it dies. I have wired up the sidestand, bank angle sensor and clutch switch, so none of them should be a problem. Also, the fuel pump does not prime when the key is turned on.
i also had a multimeter on the pink wire on the ECM to verify it has 9vto it for the anti-theft. We also took the start switch button apart and cleaned the contacts on it, and everything looked normal.
ECM problem? im at a loss....
thanks for your help
exodus1500 is offline
post #2 of 9 (permalink) Old 07-17-2005, 06:15 PM
there was a few other bikes haveing starting problems earlier last week, there are many posts containing answers and leads.
Click here and if this doesn't bring any clues Try this one
and if those don't bring any luck PM larryg, or speedwerks
post #3 of 9 (permalink) Old 07-17-2005, 11:10 PM
Sounds like one of the safety items is not properly bypassed.
post #4 of 9 (permalink) Old 07-18-2005, 12:46 AM
post #5 of 9 (permalink) Old 07-18-2005, 01:16 AM
Originally Posted by exodus1500
...Also, the fuel pump does not prime when the key is turned on...
Use your voltmeter to check the fuel pump relay and then the pump. On my old CBR, the kickstand safety switch can get crud in it because of the location. Check that one if your bike has it.
post #6 of 9 (permalink) Old 07-18-2005, 01:33 AM
Why are they bypassed in the first place.... hook em up and make sure they are in the right position and then try er again...
post #7 of 9 (permalink) Old 07-18-2005, 07:51 AM Thread Starter
my tip sensor was bypassed because it stopped working, and i bypassed the other things to make sure they werent the problem.
but anyhow......... here we go..
the battery was dead and, being sunday i couldnt find one, so i was running the power off the charger like i have done on several other bikes. after several hours of working on it, we hooked the oscilloscope up to the bike, only to find out that the charger doesnt send out the correct wave form, which in turn messes up the computer. The reason, im guessing that it starts with the starter engaged is because the alternator is putting out the correct waveform, then as soon as it stops, it goes back to the battery.
i thought a few times that it might just actually need a battery to work propperly, then just dismissed it.... lesson learned!
post #8 of 9 (permalink) Old 07-18-2005, 07:59 AM
Wow! Its amazing what happens when you do things the correct way...
post #9 of 9 (permalink) Old 07-18-2005, 11:47 PM
Believe it or not you can get MC batteries at places like Auto Zone/PepBoys/Murrays... just a FYI for next time.
