Sport Rider suspension set ups - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 42 (permalink) Old 07-29-2005, 11:52 AM Thread Starter
Exclamation Sport Rider suspension set ups
It is a wonderfull tool and the best place to start out...
SR Suspension Site
I set my 9R by the recomendations and it's AWESOME. Not too far off OE setting but just enough to make a REAL nice adjustment.
Has anybody else used this great tool? What were your findings?
post #2 of 42 (permalink) Old 07-29-2005, 11:56 AM
That's cool and all...but they don't even have my bike listed! WTF!!
post #3 of 42 (permalink) Old 07-29-2005, 12:24 PM
EIDROEDYR's Avatar
Initially, I set both the front and rear per their recommendations but I have since found that I like the front to be stiffer. I currently have my preload at 3 lines, rebound at 7 and compression at 3 - sportriders recommendations were 4, 9, 4 respectively. I left the rear alone.
EIDROEDYR is offline
post #4 of 42 (permalink) Old 07-29-2005, 12:26 PM
Not mine either? I thought for sure they would have the,
"here is the best set up for man and wife as tested section"?
Earlzach is offline
post #5 of 42 (permalink) Old 07-29-2005, 01:40 PM Thread Starter
I thought they had all the bikes...
Ryd...I and a few other WOS riders have went with what they recommend on the rear which is usually to have it softer... that way you don't get rear end skip out in mid corner on the bumps that we have so bad here in Michigan.
post #6 of 42 (permalink) Old 07-29-2005, 02:51 PM
hey they have a buell xb9r however i think the 02 model and my 05 have a slightly different front end if i am correct so i dont know if the same set up would apply.
lucky is offline
post #7 of 42 (permalink) Old 07-30-2005, 12:09 AM Thread Starter
I'm not sure about the Buell stuff...
post #8 of 42 (permalink) Old 07-30-2005, 12:40 AM
EIDROEDYR's Avatar
I'll have to double check but I am pretty sure my rear is set to their recommendations. Yeah, them bumps piss me off everyday on my ride home from work. They seem to get worse the closer I get to the crib.
post #9 of 42 (permalink) Old 07-30-2005, 12:43 AM Thread Starter
Yeah don't you love MI roads!
post #10 of 42 (permalink) Old 11-22-2005, 10:30 AM
rworkman98's Avatar
Great site, thanks!
2005 GTO IBM/Blue/MN6
1998 Kawasaki ZX-9R
1982 Datsun 720
rworkman98 is offline
post #11 of 42 (permalink) Old 11-22-2005, 11:07 AM Thread Starter
No problem!
post #12 of 42 (permalink) Old 11-22-2005, 12:41 PM
neat info. When I start getting into suspension stuff, I will use that as reference!
snadamo is offline
post #13 of 42 (permalink) Old 11-22-2005, 12:53 PM Thread Starter
It is a great reference. Easy to do as well. I put it on my 9R and it made a good difference!
post #14 of 42 (permalink) Old 06-26-2006, 03:13 PM Thread Starter
Bounce!
post #15 of 42 (permalink) Old 06-26-2006, 03:19 PM
Bounce!
Sweet! I got the magazine with the 600 shootout and i'm gonna set it up and go from there. Good to hear it worked good for your bike.
post #16 of 42 (permalink) Old 06-26-2006, 03:27 PM
Good site for everyone to learn suspension setups. I spend more on suspension than HP mods. I have more of an off road setup. Front and Rear preload at the softest. Front forks raised 1/2 inch. Cadilliac setup with plenty of sag. I like it super soft on the street, but you need a steady throttle hand. This setup is unforgiving and allows for a controlable wheel slide.
i'm saving up for a rear Ohlins and have my front forks revalved.
post #17 of 42 (permalink) Old 06-26-2006, 05:03 PM Thread Starter
I used the exact setup on my 9R and wished I did many many miles before. If you are a HIGHLY expierenced rider that pushes it hard... this will be a great starting point. But for most, these setups will be perfect and a nice improvment over the stock setups.
Also should be added that these are for a rider weighing I think 170 or so.
post #18 of 42 (permalink) Old 06-27-2006, 05:39 AM
Anyone know where I can find some recommended setting for my 92 750. Nothing on that SR website.
post #19 of 42 (permalink) Old 06-29-2006, 01:56 PM
LOL...soft suspension.
blewby142 is offline
post #20 of 42 (permalink) Old 06-30-2006, 06:03 AM
You probly look like Mladin coming out of corners.
