rear brake lever adjustment - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 13 (permalink) Old 08-05-2005, 10:36 PM Thread Starter
I did a search, and I know that alot is probably just what is comfortable. So here is my question, under normal riding conditions when the balls of your feet aren't up on the peg, where is your brake pedal located in relation to the bottom of your foot.
Where mine is now I have to ride with my foot slightly angled out and have to lift up to press the brake. I'm thinking I need to lower it so that it is just below my foot so I don't have to worry about moving my foot around uder hard corning.
thanks
fatburg is offline
post #2 of 13 (permalink) Old 08-05-2005, 11:12 PM
I'm not following... but maybe somebody elses comments will make me understand!
post #3 of 13 (permalink) Old 08-05-2005, 11:22 PM Thread Starter
my bad, I'm not very good at explaining things. I'll try again.
Under normal driving, is the brake pedal below you foot so you just have to press down? Or do you have to lift your foot up slightly to get over the pedal?
thanks
fatburg is offline
post #4 of 13 (permalink) Old 08-06-2005, 07:10 AM
The first option... Just put the foot from the ballz of my feet to just in front of my heel and push down...
post #5 of 13 (permalink) Old 08-06-2005, 07:47 AM
I have mine adjusted down a little bit from stock. It keeps it away from the bottom of my boot so I don't drag the rear brake unintentionaly. Also, it takes some of the bite away to help eliminate locking the rear. I think this is what you are getting at. When pushing things a little I keep the balls of my feet on the pegs so the brake isn't an issue. Hope that helps.
Bandit 6S is offline
post #6 of 13 (permalink) Old 08-06-2005, 08:19 AM
Adjust levers, shift lever, brake pedal to where YOU want them
its all entirely personal preference, there is no right or wrong
Als-Repsol is offline
post #7 of 13 (permalink) Old 08-06-2005, 10:49 AM
Makes a fun afternoon moving things around a little and then taking test rides to check the results. Just go easy at first because some adjustments can have a huge impact on how things behave.
post #8 of 13 (permalink) Old 08-06-2005, 08:08 PM
I agree, you need to lower the pedal.
post #9 of 13 (permalink) Old 08-06-2005, 10:58 PM
Move it if you feel the need. If you don't like it, put it back.
post #10 of 13 (permalink) Old 08-08-2005, 11:01 AM Thread Starter
thanks for the responses. The manual says it should be 1" below the peg when on the center stand but that is just i little too high so I'm gonna try to move it down .5 inch or so and see how that feels.
thanks again
fatburg is offline
post #11 of 13 (permalink) Old 08-08-2005, 11:35 AM
The guy that wrote the manual is not riding your bike, you are
Setup everything the way you like it..
I rotated my levers down, move shift lever up
never touched rear brake lever as i hardly ever use it and its fine where it is.
Set sag for my weight etc..
There are many adjustments you can make to make the bike just right for you.
post #12 of 13 (permalink) Old 08-08-2005, 05:30 PM Thread Starter
So I moved the lever down about .5 in. It's much easier to operate now. Figure I ride for a bit and see how it feels. thanks again
fatburg is offline
post #13 of 13 (permalink) Old 08-08-2005, 08:38 PM
Ya small adjustments is best!
