chain tension question - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 6 (permalink) Old 08-07-2005, 11:57 AM Thread Starter
i have a 1995 Suzuki GS500E (for sale by the way, $2500 OBO)... i noticed a whirring noise and realized my chain was pretty loose. i see the threaded bolts at the ends of the swingarm forks to move the wheel unit forward or backward. how much tension should there be on the chain when i'm done? should it be completely taught? or how much should it move up from resting position? thanks
canadaman123 is offline
post #2 of 6 (permalink) Old 08-07-2005, 12:05 PM
You need about 1/2 inch of slack. Make sure its not to tight when you set on it. Recheck the wheel alignment after you get the axel tight.
post #3 of 6 (permalink) Old 08-07-2005, 04:12 PM
I would say between .5" and 1". Most people keep theirs too tight. This can cause what appears to be the rear suspension bottoming out but can actually be the chain going taught. You can also check your owners manual.
post #4 of 6 (permalink) Old 08-07-2005, 06:05 PM
glad you asked, because having the chain too tight is way dangerous and will mess things up.
post #5 of 6 (permalink) Old 08-07-2005, 11:14 PM
It eats sprockets!
post #6 of 6 (permalink) Old 08-07-2005, 11:15 PM
Originally Posted by jeeps84
It eats sprockets!
and also you can snap your chain.
