How often do you check your tire pressure? - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 21 (permalink) Old 08-08-2005, 10:22 PM Thread Starter
Question How often do you check your tire pressure?
I just check mine at random times. No real method... do you guys do it everytime you ride, everytime you wash the bike, or everytime you change the oil...what?
post #2 of 21 (permalink) Old 08-08-2005, 10:31 PM
I check with my hands every ride. If I notice any thing strange, I get the gauge out.
post #3 of 21 (permalink) Old 08-08-2005, 10:47 PM
Every weekend unless the bike handles like it has low pressure. Usually you can feel if its wrong just by riding.
post #4 of 21 (permalink) Old 08-08-2005, 10:56 PM
I usually check mine every couple of weeks and like people above said you can tell by riding it, etc. At the track I adjust it before riding depending on recommendation, etc. What kind of pressure do you run in those Pilots on the street Gas?
Mudpuppy is offline
post #5 of 21 (permalink) Old 08-08-2005, 10:58 PM
I do a pre-check on alot of other things before I ride also. Tires are what you are rolling on...it's no joke!
post #6 of 21 (permalink) Old 08-08-2005, 11:11 PM
Everytime before I ride
ne1469 is offline
post #7 of 21 (permalink) Old 08-08-2005, 11:21 PM
Everybody needs to remember that every time you use a gauge. You actually lower the pressure. The gauge releases a little bit of air every time. It sounds trivial but a bike tire doesn't have allot of air volume to start with. Its not near as important to street rides as track days and races. Ever pound counts when ridding at race pace.
post #8 of 21 (permalink) Old 08-09-2005, 12:58 AM
Having a compressor in the garage makes checking a pleasure. Plus, the tires are still cold.
post #9 of 21 (permalink) Old 08-09-2005, 02:21 AM
I just kick my tires every few days
Samurai_Jack is offline
post #10 of 21 (permalink) Old 08-09-2005, 05:18 AM
Got to go with this as my way also.
Earlzach is offline
post #11 of 21 (permalink) Old 08-09-2005, 08:44 AM
2FURYUS's Avatar
Obviously tire pressure is critical to the handling of a bike....that being said, I don't check mine often enough. Usually every 3-4 weeks, depending how much I ride, or before any canyon riding.
YA THINK???
2FURYUS is offline
post #12 of 21 (permalink) Old 08-09-2005, 08:47 AM
EIDROEDYR's Avatar
I typically use the same process and monitor how the bike rides.
EIDROEDYR is offline
post #13 of 21 (permalink) Old 08-09-2005, 09:19 AM Thread Starter
Ya my bike handles different when the pressure changes...
MP... I run 30/32 on mine on the street. And actually the same as the track. Cause that is about 2-3#'s lower than what Kaw recomends...but I like it softer.
post #14 of 21 (permalink) Old 08-09-2005, 12:09 PM
I also run 2 pounds lower than Honda recommends. It lists the same pressure (36/42) for full load as for regular riding.
post #15 of 21 (permalink) Old 08-09-2005, 12:16 PM
Visual inspection, daily...gauge, weekly...unless, like the last 3 weeks, we have a low of hot, humid, low pressure, rainy days, and then it is everytime out
post #16 of 21 (permalink) Old 08-09-2005, 12:27 PM
The weather does play a very important role in tire pressure.
post #17 of 21 (permalink) Old 08-09-2005, 12:56 PM
I usually check it if my handling doesn't feel the same. I also apply the thumbs method.
post #18 of 21 (permalink) Old 08-09-2005, 01:57 PM Thread Starter
Yeah I think Kaw says 32/36 or somin.. I run 30/32... when I run it on their marks...on the highway it wants to turn in too fast for my liking and makes it less stable when weaving!
post #19 of 21 (permalink) Old 08-09-2005, 04:01 PM
or fill up with nitrogen and forget weather woes.
post #20 of 21 (permalink) Old 08-10-2005, 06:33 AM
Tire pressure is the single most important thing to keep up on maintance wise. It is the only thing that touchs the road. They propel you, take all the forces of you turning, and stop you. There is nothing more exciting than knowing can trust your tires pull you through a hot corner.
