keeps coming out of second - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 7 (permalink) Old 09-13-2005, 06:01 PM Thread Starter
well quite often ill shift from 1st to 2nd and the bike slips out of gear. and i go like wtf. so am i just not putting it in hard enough or what. that is the only time it does it
SperosSV650 is offline
post #2 of 7 (permalink) Old 09-13-2005, 07:12 PM
If it is stopping in neutral, you need to shift harder, or buy a stiffer spring kit...
post #3 of 7 (permalink) Old 09-13-2005, 08:03 PM
is it slipping out of 2nd only when you're being hard on it?
post #4 of 7 (permalink) Old 09-13-2005, 08:29 PM Thread Starter
sometimes. but not all the time
post #5 of 7 (permalink) Old 09-13-2005, 08:36 PM
My SV slipped out of 2nd when I was hard on it and in a high rev. It didn;t do it all the time but once in a while.
post #6 of 7 (permalink) Old 09-14-2005, 05:08 PM
Blip the throttle as you shift and trigger the clutch. that should help 2nd fall into place a little easier. If that doesnt help, pressure the shifter before and as you do all that.
post #7 of 7 (permalink) Old 09-15-2005, 03:47 AM
It might be the trany its self. If it has worn or broken teeth, it will pop out of gear.
