friends got probs with zx6r sprocket bearing - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 17 (permalink) Old 10-14-2005, 09:02 PM Thread Starter
hey guys (and girls). im posting this for a friend and he just had his zx6r sprocket bearing replaced. the bike is a 00 with 1800miles. has been wreck but nothing fast and not any frame damage. any ideas why the bearing would go out so fast??? he doesnt even play around much or anything. mostly just cruises.
biggallemore is offline
post #2 of 17 (permalink) Old 10-14-2005, 10:00 PM
Could it have a bent sprocket shaft.
I have seen chains that come off and get wound up so tight around the front sprocket to bends the shaft. Does he know if the chain has ever came off before? And this is just a guess.
Earlzach is offline
post #3 of 17 (permalink) Old 10-14-2005, 10:03 PM
Could you be a bit more precise as to what a "sprocket bearing" is? If it's what I think you are talking about, does he pressure wash his bike?
post #4 of 17 (permalink) Old 10-14-2005, 10:05 PM
Good Thought LG.
Most of the ones I have seen if it is the counter sprocket have had a seal but that dont always meen crap. Water will do it.
Earlzach is offline
post #5 of 17 (permalink) Old 10-14-2005, 11:45 PM
Yeah what is a sprocket bearing?
post #6 of 17 (permalink) Old 10-15-2005, 12:07 AM Thread Starter
hey
goes on back axel. thats what he called it. dunno if he pressure washes it. he might. chain was loose b4 but not real bad
post #7 of 17 (permalink) Old 10-15-2005, 12:09 AM
Do you/he mean a rear wheel bearing?
post #8 of 17 (permalink) Old 10-15-2005, 12:11 AM Thread Starter
dont think so
when i saw him he had both wheel bearings. they were fine.
post #9 of 17 (permalink) Old 10-15-2005, 12:12 AM Thread Starter
im not even sure how many sets of bearings there r in back of his bike. i havent seen it since we were cruisin and it started sweekin
post #10 of 17 (permalink) Old 10-15-2005, 12:22 AM
Unless there is something really wierd in the rear wheel....I'm not sure what you're talking. The rear sprocket should be directly mounted to the cush drive of the rear wheel...
stick around... LarryG will know...
post #11 of 17 (permalink) Old 10-15-2005, 02:33 AM
post #12 of 17 (permalink) Old 10-15-2005, 09:45 PM
The rear sprocket is mounted to the cush drive and the cush drive has a bearing in it (in addition to the two in the wheel). Usually, those go bad from water contamination caused by overzealous pressure washing trying too hard to get rid of chain grease.
Just a thought.
post #13 of 17 (permalink) Old 10-15-2005, 09:51 PM
LarryG
Wow!
Is this something on just that bike or, is it becoming common?
Iv had the wheel and hub off my 05 Gixxer and didn't notice an extra baring.
post #14 of 17 (permalink) Old 10-16-2005, 01:31 AM
Originally Posted by jeeps84
LarryG
Wow!
OK...so that's it... you buddy pressure washes his bike... NOT A GOOD IDEA!!
post #15 of 17 (permalink) Old 10-17-2005, 08:54 PM
LarryG
Wow!
Although this is an '04...it looks like Suzuki uses three bearings in back as well...
http://www.ronayers.com/fiche/300_03...80&parent=5840
post #16 of 17 (permalink) Old 10-17-2005, 09:03 PM
Thanks Larry
I went through several set of tires and changed the rear sprocket on my 03 Gixxer. Changed the sprocket and tires on the 05 and have never noticed it. I'm due a new rear soon (3400 miles on Pilot Power and still some left) I guess I need to pay more attention.
post #17 of 17 (permalink) Old 10-17-2005, 10:24 PM
interesting....
