messy @$$ luber - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 12 (permalink) Old 10-27-2005, 06:52 AM Thread Starter
messy @$$ luber
Do all cable lubers barely work or is it just mine. I got mine with a can of lube and i probably gets 50% to the cable and 50% into the rag i have to wrap it with. they all like that? 'cause everyone ive used is messy.
post #2 of 12 (permalink) Old 10-27-2005, 09:40 AM
Generally I just use WD40 or Kero to clean it then some white lithium on it... however, I have heard good things about Kleen Chain.
post #3 of 12 (permalink) Old 10-27-2005, 12:54 PM
There all a PITA except the speedO. You can usually just remove it.
post #4 of 12 (permalink) Old 10-27-2005, 10:22 PM Thread Starter
i ask because i saw a motion pro cable luber on the SW site. wondering if its worth the effort.
post #5 of 12 (permalink) Old 11-03-2005, 10:47 PM
Most of them suck but aren't too bad if you use the right technique.
post #6 of 12 (permalink) Old 11-03-2005, 11:09 PM
post #7 of 12 (permalink) Old 11-04-2005, 07:17 AM
Do you mean start your bike, put it in gear and then lube it?
J/K
post #8 of 12 (permalink) Old 11-04-2005, 07:52 AM
J/K
post #9 of 12 (permalink) Old 11-04-2005, 02:06 PM
BusaBabe's Avatar
The guys here lube after a ride.
BusaBabe is offline
post #10 of 12 (permalink) Old 11-04-2005, 02:11 PM
Doesn't everybody?
post #11 of 12 (permalink) Old 11-04-2005, 05:42 PM Thread Starter
guess were not talking about cable lubers anymore....
post #12 of 12 (permalink) Old 11-05-2005, 11:00 PM
sometimes I lube before a ride.
