synthetic oil question - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 18 (permalink) Old 10-31-2005, 04:29 AM Thread Starter
at how many miles do you start using synthetic oil on your bike? I have a 2001 R1 with 7500 miles on it.
sleeper_red is offline
post #2 of 18 (permalink) Old 10-31-2005, 07:50 AM
In case I missed it b4!
I didn't change mine over till like 5k or 6k on my 9R. Blade could check and tell ya...
What I have heard is that you definately don't want to do it within the first couple oil changes. The deal is... you need your piston rings to seat properly. With the syn oil, they don't cause they just slide up the cyclinder walls to easily.
But this is quickly becoming one of those ageless questions... kinda like the one... do you baby it or beat it right out of the box...
post #3 of 18 (permalink) Old 10-31-2005, 11:06 AM
I put Synthetic in at the first oil change because I didn't know any better but everything works good. I got 14K on it now.
post #4 of 18 (permalink) Old 10-31-2005, 11:19 AM
jtemple's Avatar
I put dino oil in mine for the first oil change (500 mi.). The next change is schedule for 4000 mi. I plan on putting synthetic in at that point. The bike currently has about 2200 miles on it.
2006 Kawasaki ZX-10R
jtemple is offline
post #5 of 18 (permalink) Old 10-31-2005, 04:55 PM
Jt...that sounds ok... but I'm not sure about the intervals of your oil changes!!!
post #6 of 18 (permalink) Old 10-31-2005, 09:51 PM
My book say's the same 600 then 4000.I had the dealer do it at around 600 and then I changed it to mobil 1 syn. for motorcycles around 2500.I did get a weird "white haze" on the crank case sight glass though,but I'm not sweatin it,as long as the level is full and pressure is in specs...
JEKYLL is offline
post #7 of 18 (permalink) Old 10-31-2005, 11:09 PM
jtemple's Avatar
The owner's manual says the next oil change is at 4000 miles...
jtemple is offline
post #8 of 18 (permalink) Old 11-01-2005, 12:01 AM
i stuck to dyno on the 600 break in then did it agian at 4000 miles with dino... wont go 3400 bwtwene changes with dino agian.. was as bad as a car with 3400... went to Motul synthetic at 6000, then let it go three thousand and felt perfeclty slick at the 9000 change.. im at 11 and may let it go 4K with the good stuff.. since faoctyr reocmendation on my bike is every 7,500 miles.. No way would i go that far.
Id say your safe though after the 600 change.. run that to at least 2,000 then change, but like gas said.. its all opinion
ScottSellersUNR is offline
post #9 of 18 (permalink) Old 11-01-2005, 03:56 AM
Check out my post on Proper Break-in Procedure.. It goes against at lot of what we have been told but it does make a LOT of SENSE.
Check it out. Proper Break-in Procedure?
Blade1413 is offline
post #10 of 18 (permalink) Old 11-01-2005, 10:23 AM
My system is to use synthetic blend on the first oil change then convert to full synthetic for the rest. I have never had any issues doing this. Some swear by this method while others still say no.
post #11 of 18 (permalink) Old 11-01-2005, 01:48 PM
I am just saying that 3,400 miles sounds a bit long for a bike change interval. Especially on convential oil!
Jeeps... you're doesn't sound that bad!
post #12 of 18 (permalink) Old 11-03-2005, 09:07 PM
jtemple's Avatar
I think I'm going to change it this weekend & switch to synthetic. I'm at around 2700 miles. So, it's been 2200 miles since my last change.
jtemple is offline
post #13 of 18 (permalink) Old 11-03-2005, 11:40 PM
I should have added. I do my first change around the 2 hundred mile mark. Then again after the 6 mark. From there it really depends on the riding. Weekend at the track or hard days in the twisties. Its always less than 3K miles.
post #14 of 18 (permalink) Old 11-04-2005, 07:23 AM
That's my point... 3k or more on bike oil that's not full synthetic!
post #15 of 18 (permalink) Old 11-04-2005, 07:47 AM
Its a cheap PM. Why not stay on top of it.
They claim the synthetic oils are capable of twice the mileage and torture. I just never let that mess with my schedule. I use the claim of better oil to justifies getting lazy with my oil changes after hard weekend rides.
post #16 of 18 (permalink) Old 11-04-2005, 02:19 PM
if i changed my synthetic after every hard week of ridng id do like 20 oil changes or more a year... with 15 of em in summer. at 40$ a change thats expensive... more then tires per year.
post #17 of 18 (permalink) Old 11-05-2005, 11:03 PM
Some of my weekend trips can be more demanding on a bike than a day at the track.
post #18 of 18 (permalink) Old 12-01-2005, 12:46 AM
Bump for ZZRider.
