changing oil...please help with removing the fairing - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 10 (permalink) Old 11-05-2005, 11:04 PM Thread Starter
Hi guys,
I bought a used 2001 R1 and I want to change the oil for the first time. Just want to ask how to remove the fairing so I can get to the oil filter and drain plug. thanks guys. don't have a manual yet so please bear with me.
sleeper_red is offline
post #2 of 10 (permalink) Old 11-05-2005, 11:11 PM
Yeah that's a stupid Yam design! Why in the f**k they designed those bikes that way....
Follow the screws and eventually the fairings will come off!
post #3 of 10 (permalink) Old 11-05-2005, 11:13 PM
There is an assortment of Allen screws an push/pull buttons that need to be removed to take off the lower fairings. The oil drain should be easy to get to. You will need a socket type filter wrench to get the filter off also. No room for the handle type.
post #4 of 10 (permalink) Old 11-05-2005, 11:16 PM Thread Starter
could you please be more specific on which screws to remove? thanks. photos will be appreciated. thanks. sorry guys. first bike, first time.
post #5 of 10 (permalink) Old 11-05-2005, 11:21 PM
Maybe you just need to take it to a shop or enlist the help from some one that knows how.
No bashing intended. Sometimes its just easier if some body show you how its done in person or pay somebody to do work for you. Something as simple as striping the threads on a drain plug of filter can be very expensive to repair.
post #6 of 10 (permalink) Old 11-06-2005, 11:42 AM
Not a bad idea Jeeps.
But serioiusly... disassembly is the easiest part. Just start looking for screws and bolts... with a little bit of time it will come off. Make sure you keep your screws in bowl, pan, or like me...a muffin pan or ice cube tray.
post #7 of 10 (permalink) Old 11-06-2005, 11:50 AM
Just remember if the fairing acts like its still attached somewhere. It probably is. Don't force anything.
post #8 of 10 (permalink) Old 11-06-2005, 12:01 PM
Well yeah!
post #9 of 10 (permalink) Old 11-06-2005, 03:59 PM
Just by looking its pretty obvious which screw are holding the fairing on and which ones are not................. if cant see that then you should probably get someone else to do it.............
Als-Repsol is offline
post #10 of 10 (permalink) Old 11-06-2005, 08:25 PM
We all have to start some where. That's why I suggested enlisting help from a knowledgeable person to aid in a hands on job.
