shift timing indicator light - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 25 (permalink) Old 11-07-2005, 12:12 AM Thread Starter
kem
Hey Guys,
I'm trying to set my shift timing indicator light on my R6. I'm following my owner's manual, and I can't even get started. The manual says to push the RESET button to select one of the indicator light acitivity settings, but it doesn't mention whether the key should be in the "ON" or "OFF" position. I've tried both anyway and when I push the RESET button, nothing happens. What am I doing wrong? Anyone who has a R6 or is familiar with R6 settings, please help. Thanks.
kem is offline
post #2 of 25 (permalink) Old 11-07-2005, 12:26 AM
The key will have to be ON. You have to hold the button in for a few seconds.
post #3 of 25 (permalink) Old 11-07-2005, 09:00 AM
Exactly... there is no way to do anyhting with the dash with the key off!
post #4 of 25 (permalink) Old 11-07-2005, 11:50 PM
You could use a hammer on it with the key off. That would get results.
post #5 of 25 (permalink) Old 11-08-2005, 10:50 AM
You need to push the reset button in while the key is off and then turn the key on while holding the reset button still. You will need to cycle through the backround light, then the shift indicator light before you can adjust which RPM's the indicator will go on/off. I believe that's how I did it on my '04. If that doesn't work, let me know and I will look at my manual.
post #6 of 25 (permalink) Old 11-08-2005, 08:21 PM
There ya go... DL has a R6 and would know better!
post #7 of 25 (permalink) Old 11-09-2005, 01:41 AM Thread Starter
kem
Thanks DLITALIEN. I'll give it a try.
kem is offline
post #8 of 25 (permalink) Old 11-09-2005, 06:41 AM
Check back and let us know if it works!
post #9 of 25 (permalink) Old 11-14-2005, 11:08 AM
Well?
post #10 of 25 (permalink) Old 11-14-2005, 11:36 AM
Originally Posted by DLITALIEN
Well?
What's the dilly yo?
post #11 of 25 (permalink) Old 11-14-2005, 05:18 PM
...i think you have to hold the button down for a while, then cycle thru the menu's.
post #12 of 25 (permalink) Old 11-14-2005, 05:19 PM
post #13 of 25 (permalink) Old 11-16-2005, 12:18 AM Thread Starter
kem
Sorry for the delay guys. I got it to work...just wanted to update that fact to you guys. Thanks people. Hey, I posted a new thread about sliders...please input your thoughts.
kem is offline
post #14 of 25 (permalink) Old 11-16-2005, 10:02 AM
Ya good... see you don't realize just how much do you?
post #15 of 25 (permalink) Old 11-16-2005, 10:14 AM
Was I right?
post #16 of 25 (permalink) Old 11-16-2005, 12:06 PM
Was I right?
Sounds like you were to me. I would just run with that...
snadamo is offline
post #17 of 25 (permalink) Old 11-16-2005, 12:21 PM
I'd like to know cuz if I'm not I'd want to know the right way.
post #18 of 25 (permalink) Old 11-17-2005, 04:11 AM
You could always test your own theory.
post #19 of 25 (permalink) Old 11-17-2005, 10:34 AM
Bike is in the shop still.
post #20 of 25 (permalink) Old 11-17-2005, 12:44 PM
